Hi, Is there some way I can mathematically know the bitrate for the required screen size so that there will be no distortions on playback and you can be sure about that it is the required bitrate for a particular screen?
No bitrate calculator can tell you how much bitrate a video needs to maintain image quality. Use constant quality encoding. You always get the quality you ask for. The encoder uses whatever bitrate is necessary at each frame.
How to create M4V files w/AC3+AAC from M4V w/AC3 only??
By williamlondon in forum MacReplies: 4Last Post: 5th Oct 2010, 16:15 -
calculate quality of a movie??
By Cazz in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jun 2009, 07:55 -
How do i calculate the correct bitrate for Xvid codec?
By Ingolf in forum Newbie / General discussionsReplies: 4Last Post: 9th Jan 2009, 09:32 -
P-STD buffer underflow: how to calculate correct bitrate?
By fvisagie in forum Authoring (DVD)Replies: 4Last Post: 6th Oct 2008, 10:51 -
Formulas used to calculate bitrates.
By ziggy1971 in forum Newbie / General discussionsReplies: 16Last Post: 6th Oct 2007, 02:00
