Hello,
I have two, possibly three,difficulties with AviSynth video creation.
The overall aim is to make ashort video from a still image.
1. For one of my scenes I wouldlike to float an image in from the left edge of a ‘black’ 400 x 300 pixel frameso that the whole image fills the frame over a period of 88 frames. The aimed for effect islike sliding a physical picture into a frame.
2. For two other scenes, illustratingaudio sampling and quantisation, I would like at regular intervals, say everyfifth frame, insert successive thin vertical lines across an image, followed bysimilar horizontal lines moving up a different image.
Are there an appropriate ‘animate’expressions in AviSynth?
Guidance and advice will beappreciated.
Thank you
Hungarian
(Hannes W. Herold)
For #1 , you can probably use transwipe from transall plugin
http://avisynth.org/vcmohan/TransAll/docs/index.html
I don't understand what you are asking in #2? do you want the lines to animate vertical lines to the right, horizontal lines upward ? -
Hello,
Thank you for advice.
Re 2. I want to draw vertical lines at regular intervals i.e. progressing from left to right accross an image
Additionally, but on a seperate image, i want to draw horizontal lines at regular intervals from the bottom of the image to the top of the image.
The effect I am aiming for is like a sheet of lined writing paper viewed in landscape orientation and then viewed in portrait orientation e.g.
and
__________
__________
__________
Further advice will be appreciated.
Hungarian -
One way to add the lines to your clip is to overlay a blank clip of the desired color using an appropriate mask to get the line pattern. The mask may be created using the MaskTools function mt_lutspa().
Write a function that produces the lines you want, with a paramater to specify the (vertical or horizontal) position of the first line. Then to make the lines move, you can Animate this function, varying the parameter.
This is not a trivial task so you may need further help, especially if you are not familiar with MaskTools.
Start by reading the relevant documentation and ask again if you get stuck.
Animate Videos (2D)
By Xaser in forum Newbie / General discussionsReplies: 3Last Post: 12th May 2011, 08:22 -
Animate and Subtitle Script
By sambat in forum Video ConversionReplies: 4Last Post: 18th Jun 2010, 12:17 -
avisynth
By sportflyer in forum Newbie / General discussionsReplies: 1Last Post: 16th Feb 2010, 04:36 -
AVIsynth help!
By helper in forum Newbie / General discussionsReplies: 11Last Post: 15th Oct 2008, 03:35 -
How do I animate drawing a line with After Effects?
By Mysteriouskk in forum Newbie / General discussionsReplies: 1Last Post: 24th May 2007, 16:44
