    Aug 2011
    Maryland, USA
    I'm new to using Pinnacle Studio 14. I have edited together a video project in one file... and edited together an opening sequence montage in another. I'd like to add the completed montage to ther main video... without having to rebuild it from scratch. Is there a way to combine the 2? Thanks in advance for any input.
  2. Member JohnP's Avatar
    Apr 2004
    Somerset UK
    I'm on Studio 11, but, you should be able to copy the 'timeline' from your opening sequence and paste into the start of your main project, or - and this is what I do, output your opening sequence to a file (DV) and simply import your clip into the start of your main project.
  3. Member zoobie's Avatar
    Feb 2005
    Florida
    Most editors can insert a project. However, the exact same settings usually must be used.
