I wish someone can help me in solving this problem. After renaming all the RMVB
movies (RenameMaestro and copy to DVD, the Episodes are in what I wanted but when you play it
in TV the Episodes is not what I have wanted the first episode will display in
to the last track some is OK. After looking at the mediainfo most are
the same except this particulars in some episodes, where the different is in the bit rate. I do hope someone can help me out. Thanks
They are not in the proper order, from first to last?
If you named them 1,2, 3...... 9, 10, 11, etc., then '1' might come first, then 10, 11, 2, 3, etc. Computers number differently. 01, 02.. or A, B, C, D might work better.
If you have a different problem, you would need to explain it better.
And welcome to our forums.
Thanks redwudz as I said I will let you know the result. The result is the same. I tried what you mentioned and try after I have a numbers of the episodes for trial with the numbering method method mentioned. You know instead of enjoying the movie without having to restart to another episode. Well any further method will be much appreciate from you all. At the meantime I am looking for a software that can recode the rmvb to rmvb but have the option to set the bit rate.
Renaming video files?
By c4bdriver in forum Newbie / General discussionsReplies: 5Last Post: 19th Mar 2011, 08:09 -
renaming vob files to mpg
By lordhutt in forum DVD RippingReplies: 22Last Post: 9th Aug 2010, 20:59 -
How to Convert Popular Video Formats to RealMedia Files (eg: rmvb)?
By devilcoelhodog in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2008, 21:09 -
Crash on renaming AVI files
By Captain315 in forum ComputerReplies: 10Last Post: 7th May 2008, 05:05 -
I've got a problem with some .RMVB files
By architectofpain in forum Video ConversionReplies: 6Last Post: 18th Dec 2007, 22:47
