Hi all !
I've got this mp4 from which I need to extract a 2 minutes sample, while keeping the exact same quality. I use FFmpeg with a very simple command line :
-acodec copy -vcodec copy -t 120 -ss XX:XX:XX
Problem is, it yields an unsynched audio. It seems to be doing that exclusively with mp4's ; I use the same line with m2t's, avi's, wmv's, no problem.
Here's what MediaInfo tells me about the source :
The source is synched. It looks pretty usual to me, nothing extraordinary like some weird codec or unusual frame rate or whatever. I don't understand whence this unsync might come...Code:General Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 478 MiB Duration : 16mn 4s Overall bit rate : 4 155 Kbps Writing application : Lavf52.32.0 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L3.0 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 16mn 4s Bit rate mode : Variable Bit rate : 4 042 Kbps Width : 720 pixels Height : 480 pixels Display aspect ratio : 3:2 Frame rate mode : Constant Frame rate : 29.970 fps Standard : NTSC Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.390 Stream size : 465 MiB (97%) Language : English Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 16mn 4s Bit rate mode : Variable Bit rate : 108 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Compression mode : Lossy Stream size : 12.4 MiB (3%) Language : English
I've tried to use some filters, like -vf "null" or -vf "copy", to no avail.
So if anyone has an idea how to possibly fix it, or at least what exactly could cause this, that would be great !
Thanks a lot for your time !
I get same issue with multiple encoder's when tring to go to mp4. On the re-encode your tring to do are you keep the same Frame rate? Does audio keep same with it's sync over time or does it get worse.
Yes, it's the same frame rate, stays 29,97 input and output.
And it does stay the same over time. -
Sure that would be a solution for this time... I just hope it doesn't happen too often.
Anyways, I found another solution by using MPEG Streamclip. It does exactly what I need, and sometimes faster and better than FFmpeg. I'll see where I can go with that.
Thanks !
FFmpeg error trying to convert audio in mp4
By Thunderhead2772 in forum Video ConversionReplies: 4Last Post: 30th Jan 2015, 10:24 -
mp4 to mpeg with ffmpeg - no audio
By ilpilo in forum Video ConversionReplies: 15Last Post: 29th Mar 2012, 10:17 -
ffmpeg help... convert mp4 to jpeg array, and back to mp4 - problem!
By SaskVideoMaker in forum Video ConversionReplies: 2Last Post: 4th Feb 2011, 05:53 -
Audio out of sync problem with FFMPEG encoding MP4 (h.264,AAC)
By jenak1980 in forum Video ConversionReplies: 7Last Post: 5th May 2010, 02:03 -
FFMPEG AVI (XVID) to IPOD Mp4, AUDIO OUTPUT is 2x Normal Speed, HELP!
By jiulonghks in forum ffmpegX general discussionReplies: 1Last Post: 21st Sep 2008, 00:35
