  1. Hi, I`m new here so please be patient.
    I have Toshiba DR20KB DVD recorder and it`s really easy to use . I have a problem though, in that if I am recording a channel then I cannot watch SKY, or if I set it to record while I am watching SKY , then it will turn SKY off when the recording begins.
    I am not really technically minded, so any replies - please keep it simple.
    Hope there is a solution to this.
    Thank you.
  2. Member DB83's Avatar
    Jul 2007
    You might help your cause if you state the following:
    1. The make/model of your Sky Box
    2. Sky or Sky+
    3. or HD box
    4. How is the Sky Box connected to the dvd-recorder - description of cables etc
