I originally posted this in the "Audio" section, but now realize this is probably the better place for it... sorry for the double post.
I have an MKV file that is unable to play on my blu ray player because the reference frame # is too high. For some reason the audio gets out of sync when playing on my computer - the audio gets ahead of the video and gets worse the longer I play it. Strangely, it plays perfectly on another computer (not one I own) yet my computer is better in every respect that I can tell. Here are the specs:
My computer: Win XP, Pentium 4 2.4GHz, 2 GB Ram, Geforce 6200 AGP video card, Sound Blaster Audigy 2 ZS soundcard.
Computer that plays it perfectly: Win XP AMD Sempron+ 3300, 2GHz, 256 MB ram, onboard sound, onboard video
I have reformatted my system, installed a fresh windows and used the same codec to test both computers: klite basic playing with Windows media player. I have tried numerous other players and codecs on my system. I also have the most recent drivers for my video and audio cards.
Any ideas what's wrong??? I could recode but it would take very long and the video quality would decrease.
You could open the task manager and see if the cpu usage approaches 100% when the file is playing.
If so, it may account for the problem. -
Thanks for the reply. The cpu usage is at 100% most of the time, but its the same with the other computer. This must be fixable somehow. I just don't understand how a computer with onboard video and audio can play the file fine, but mine can't.
Any other ideas/fixes? -
could be a problem with the codec pack. they are mostly despised around here. try a player that uses it own like vlc.
i thought i had already replied to your thread and i had. don't double post.
open up task manager and click on the processes tab click cpu twice to bring the highest to the top and see what is using all the cpu cycles.Last edited by aedipuss; 4th Aug 2011 at 16:38.
Again sorry for the double post, in retrospect the audio forum was not the correct place to ask my question. I tried to see if I could delete it.
I didn't know any players had their own codecs. I will uninstall the codec pack and try vlc again. I'll also check the processes and post an update. Thanks for the input! -
How would I turn on DXVA - through the nvidia software or in the media player?
Here's an update of what I've tried. Fresh install of XP. Without installing any codec packs I tried several players. VLC is the only one with in sync audio, but the video was very choppy. Everything else including MPC-HC had fluid video with audio track getting ahead within seconds.
Thanks for the Replies! -
I don't think it's going to work. Sorry to bring bad news,
I read a little more and it seems the chipset is only capable of acceleration at SD res.
See the paragraph "naming conventions"
http://en.wikipedia.org/wiki/Nvidia_PureVideo
Playing MKV with multiple audio tracks - does it load computer more?
By tufffta in forum Software PlayingReplies: 6Last Post: 4th Mar 2012, 18:44 -
audio out of sync with MKV files, but an inferior computer plays perfect
By dave in or in forum AudioReplies: 3Last Post: 4th Aug 2011, 16:32 -
a/v sync - computer plays ok, pmp not
By adom in forum Video ConversionReplies: 3Last Post: 20th Mar 2011, 06:19 -
problem playing MKV file on a strong computer
By tomchook in forum Software PlayingReplies: 9Last Post: 25th Mar 2010, 19:53 -
Video DVD that doesnt play audio on DVDplayer but plays fine on computer ?
By hiavi in forum Video ConversionReplies: 6Last Post: 15th Jan 2009, 15:01
