    Jun 2010
    U.S.A.
    What would be the best program for this ?
    Jun 2010
    U.S.A.
    Will try those
  3. x264
    I wouldn't use anything that uses Quicktime components. They completely screws up levels.
  4. Member Cornucopia's Avatar
    Agreed. x264 is both FASTER, and MUCH BETTER quality than the h.264 codec used in Quicktime. Once it's an h.264/MP4, it's easy to re-wrap/transcode that to QT/MOV (with no loss).
    Jun 2010
    U.S.A.
    So what is a good program to convert Uncompressed AVI to .x264 ?
  6. x264 is a command line program. There are many graphic front ends like xvid4psp, handbrake, megui, etc.
  7. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    RIPBOT264...Easy way for HQ files.
