Good for all
I need some help, I have a mkv file that ripped in x264. And when I go to add the audio it gets out of sync. already checked with the media looking for info on the audio delay, but it gives me no value. the source has two audios, with the first 22 ms of delay, the second that I want to use has no value. if I join mkv + without delay the audio is out of sync, if I put in 22 ms delay is also out of sync.
If anyone can help me, I am thankful since already
Greetings to all
PS. Sorry for the english, I'm Portuguese
Results 1 to 9 of 9
Have you tried a higher value than 22ms? Just too see if it make any difference.
And I assume this is a constant out sync. If it get worse and worse it's much harder to fix. -
I tried putting 25ms. and the audio is still delayed compared to video.
I previously converted the DTS audio to AC3, but with both the AC3 audio as the source of the DTS in the result is the same.
A screen in mkvmerge
When adding raw video streams to MKVmerg it is unable to determine the video's FPS (frames per second), and defaults to 25 fps, at least when adding h264 raw video strteams.
Did you set the properties for your video stream? -
dragonkeeper thanks the audio sync is now right
Baldrick thanks to the time lost with this question
Thank You to 2
MKV 3D SideBySide with MKVMerge
By klode in forum Video ConversionReplies: 0Last Post: 12th Jun 2011, 08:54 -
MKVMerge problem , audio out of sync - says This AC3 track contains 227 byt
By PSPGamer in forum DVD RippingReplies: 2Last Post: 20th Apr 2011, 17:38 -
making mkv using mkvmerge
By selv00201 in forum Video ConversionReplies: 8Last Post: 18th Apr 2011, 13:06 -
Problem joining 2 MKV into 1 with MKVMerge.
By LiBiDoXP in forum Video ConversionReplies: 4Last Post: 29th Dec 2010, 02:07 -
Stretching audio in MKV files with mkvmerge GUI
By carlmart in forum Video ConversionReplies: 0Last Post: 29th Aug 2010, 11:41
