  1. Hi all,
    I'm trying to convert an M2T file, specifying bit rates during the conversion. I'm using the following FFMPEG command line (under windows):
    ffmpeg -y -threads 2 -i "nature.m2t" -vcodec libx264 -fpre "test.ffpreset" -bufsize 600 -maxrate 20000 -b 10000 -acodec mp2 -ac 2 -ar 48000 -ab 160k -f mpegts -metadata service_provider="OurCo" "nature-bitrate-10000.m2t"
    The contents of test.ffpreset is below:
    coder=0
    flags=+loop
    cmp=+chroma
    partitions=+parti8x8+parti4x4+partp8x8+partb8x8
    me_method=epzs
    subq=5
    me_range=16
    g=100
    keyint_min=25
    sc_threshold=40
    i_qfactor=0.71
    b_strategy=1
    qcomp=0.6
    qmin=10
    qmax=30
    qdiff=4
    bf=16
    refs=2
    directpred=3
    trellis=0
    flags2=+bpyramid+wpred+dct8x8+fastpskip
    However, I get the following message during the conversion:
    [libx264 @ 01EC0B20] VBV maxrate specified, but no bufsize, ignored
    This is the ffmpeg version information:
    ffmpeg version git-N-30344-g5501afa, Copyright (c) 2000-2011 the FFmpeg developers
      built on May 27 2011 22:37:57 with gcc 4.5.3
      configuration: --enable-gpl --enable-version3 --enable-memalign-hack --enable-runtime-cpudetect --enable-avisynth --enable-bzlib --enable-frei0r --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enable-libgsm --enable-libmp3lame --enable-libopenjpeg --enable-librtmp --enable-libschroedinger --enable-libspeex --enable-libtheora --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib --pkg-config=pkg-config
    Can anyone offer any suggestions as to when it's saying I'm not specifying bufsize, when in fact I am?
    Andy
    Sep 2007
    Europe
    Set buffersize to 600k.
    Also check out bitrate and maxrate. Shouldn't that be -b 1000k and -maxrate 2000k?
  3. I figured it would probably be something simple!
    Now seeing:
    [libx264 @ 01FF28E0] VBV buffer size cannot be smaller than one frame, using 800 kbit
    I'm calculating the buffer size as bitrate * 3 / FPS (10000 * 3 / 50 = 600) based on advice at https://trac.handbrake.fr/wiki/VBVRateControl. Why does it think it needs to be bigger?
    Thanks for the pointer so far!
    Andy
    Sep 2007
    Europe
    10000 is a bitrate of 10 kbps for FFmpeg which seems rather unrealistic for me, even for x264.
  5. Ok, but same applies for 2000 and 5000. I get a similar error saying that the buffer size is smaller than a frame. These are all 'k' obviously (10000k, 5000k and 2000k). And the buffer size I'm specifying for 10000k is 600k, but it says that's too small and uses 800k.
    Andy
