  1. Help.. I have a Sanyo VPC-CG20 and cannot get the recorded (HD) video to play back on my PC.. either the Windows Vista (see my profile) or an XP machine. The playtback appears to be in slow motion and is very distorted.. teh picture does display but has alternate lines (maybe 10 pixels high each) slightly offset.
    I have tried quick time / VLC / Windows Media
    I don't think it is the performance of my machine.
    I am assuming it is something to do with the codec but do not know what to install of where to install it (I am pretty new to all of this).
    I wil try to get a screen capture and upload it of that wil help.
    Media info..
    General
    Complete name : C:\Users\Houli\Desktop\SANY0066.MP4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 268 MiB
    Duration : 2mn 10s
    Overall bit rate : 17.3 Mbps
    Movie name/More : SANYO DIGITAL CAMERA CG20
    Encoded date : UTC 2011-02-03 22:07:39
    Tagged date : UTC 2011-02-03 22:07:39
    Origin : Digital Camera
    TAGS : O DIGITAL CAMERA
    Video
    Format : AVC
    Format profile : Main@L4.0
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Duration : 2mn 10s
    Bit rate : 16.9 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 59.940 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.136
    Stream size : 262 MiB (98%)
    Language : English
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 2mn 10s
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Compression mode : Lossy
    Stream size : 3.96 MiB (1%)
    Language : English
    Material_Duration : 130240
    Material_StreamSize : 4154927
    I'm at a bit of a loss so any help appreciated.
    Many thanks
    Oct 2005
    666th portal
    samsung is a company that never wants to pay licensing fees so they go their own way with oddball encoders. try installing ffdshow and haali media splitter and see if it improves.
  3. fourcc = MP42
    ffdshow includes an MP42 decoder. Also the old Microsoft Mpeg 4 Part 2 codec.
