It's possible to change what the header says. But that doesn't change actual properties of the video. Fortunately, encoders rarely use more than 5 re-frames so most of the video will probably play. The question is, what happens when you hit a section that uses >5 re-frames? Will the player crash? Will you get a garbled picture for a few seconds?
tried the h264info program. Media info listed the file as having 5 ref frames, but actually playing the video had the same effect as the file with 8 ref frames - which is blocky artefacts around motion. Does the h264info program only change the header?
Thanks for the input.
Any other ideas or programs to try?
I would just play the file on my computer and display it on my TV, but all of the media players make the audio out of sync. Recoding the file makes it work on my blu ray, but the conversion process will take about 2 days - I've been working with a 1 minute section. -
You can't change the actual properties (re-frames) of the video without reencoding.
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 14:13 -
Change avc level and reference frame
By cote112 in forum Video ConversionReplies: 2Last Post: 24th Mar 2011, 10:45 -
Help with understanding when to change frame rate
By mlaran in forum Video ConversionReplies: 3Last Post: 22nd Feb 2010, 10:11 -
PS3 AVCHD, Ref Frame 8+Level 5.1+B-Pyramid...????
By NiGHTsC in forum Video ConversionReplies: 1Last Post: 29th Dec 2008, 18:45 -
CCE keeps on trying to change my frame rate?
By friedtofublocks in forum Video ConversionReplies: 17Last Post: 14th Dec 2007, 05:21
