So I've done some captures and intend to produce a fair bit of HD footage from a Go Pro HD camera over the next few months.
I've been recommended looking at Magix Edit Pro 17 so I've got it setup and had a little play with it. I've found the Ad Break detection part but it hasn't worked 100% - although it has allowed me to drag the markers around myself to get the selections correct then right click them to remove the ad.
Does anyone know if its possible to add the starting and ending ad break marker manually at the current position in the video??
If I can manually add them it will speed up the selection no end.
Failing that, some details or a guide on a manual method of selecting (i.e. start and end) to allow me to cut out the video I don't need.
only a few here have tried magix
you can always ask in their support forum I suppose
may have better luck -
Why don't you post the log file from Mediainfo a file inspection program that reveals most of the parameters of a video file - this will at least give some information of the type of file you are working with and what alternative software packages may give better results.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
I'm working with h262 in a m2ts file, ripped using a HD PVR at 1080i.
I'm open to suggestions on alternitives but i'm looking for a quick learning curve as the stuff I'm after doing isn't all that complicated so I on't want to spend too much time learning the software if possible. I've tried the likes of Vegas and Premier but they seem far too complicated, also tried pinnicle studio but found it a but unstable.
Magix Movie Edit Pro 17 - Help
By volotre in forum EditingReplies: 1Last Post: 12th Apr 2011, 11:27 -
Magix Movie Edit Pro 17 for .mts
By Buckskin in forum Video ConversionReplies: 0Last Post: 2nd Oct 2010, 14:51 -
VideoStudio Pro X2 OR Magix Edit Pro 15 Plus ?
By Dash1 in forum EditingReplies: 1Last Post: 25th Jun 2009, 19:26 -
By zoobie in forum EditingReplies: 5Last Post: 19th May 2009, 18:04 -
MAGIX Movie Edit Pro 12 problem
By Rein Engel in forum EditingReplies: 0Last Post: 21st Sep 2007, 13:40
