when i do dual layer svcd2dvd out puts bigger and wont fit on disk
Well, yes it would be a larger output file. Are you using dual layer discs?
Dwight
"A positive attitude may not solve all your problems, but it will annoy enough people to make it worth the effort."
- Herm Albright
www.martialconcepts.com
Output file is way bigger than input file in Virtualdub
By sasuweh in forum Video ConversionReplies: 31Last Post: 10th Oct 2013, 17:25 -
Does Bigger = Better when it comes to TV Antennas
By the_importer in forum DVB / IPTVReplies: 10Last Post: 4th Jan 2012, 12:52 -
LCD Monitor Screen Size, bigger isn't really bigger?
By Des in forum ComputerReplies: 13Last Post: 27th Dec 2011, 14:13 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 15:17 -
I need a bigger C: drive
By sdsumike619 in forum ComputerReplies: 14Last Post: 15th Oct 2008, 09:01
