Hello, boys and girls
This is my problem i wona watch movies in avi or xvid or divx on dvd-player, but when i try to convert movie in that format and watch it on dvd-player it wont work sometimes, i dont now why, some movies work and they are shown in the picture so i hope you can tell me whats the best way to convert movies in avi for my dvd-player?
MOvies on picture work!!!
http://imageshack.us/photo/my-images/818/movie2z.jpg/
http://imageshack.us/photo/my-images/88/movie1v.jpg/
As far as I can guess:
In Xvid or DivX configuration:
1-Don't use Qpel
2-Don't use Packed Bit Stream
3-Keep video resolution compliant
with DVD standard.
Audio:
4-Don't use to low sample rate. -
If you have an avi that doesn't work it's easiest to just reconvert with avi recomp. It will make it work on most avi divx players.
If you convert yourself then try autogk and make an avi divx or xvid. -
This expands a little on locotus' post.
https://forum.videohelp.com/threads/290800-My-DivX-DVD-Player-can-t-play-my-avi-DivX-xvid-video -
ok, so what is the best softwer to convert all to avi, for my dvd player, and on what parametars i need to watch out?
thanks
The link in my post tells you what parameters NOT to use. Did you even look?
Encoders aren't very different, but what format are your sources? Do you need a very simple to use encoder or are you willing to use something that gives you more control but requires you to set more values in it? -
simple but afectiv that is what i wont, to convert from lets say "mkv" to "avi" and watch it on dvd player.
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
Found DVD/AVI software player that displays Chinese srt subtitles with avi
By jimdagys in forum Software PlayingReplies: 1Last Post: 14th Nov 2009, 20:45 -
Avi issue/dvd player
By nanrector in forum Newbie / General discussionsReplies: 7Last Post: 28th Jul 2009, 17:39 -
.avi dvd player?
By cx420ns in forum DVD & Blu-ray PlayersReplies: 13Last Post: 3rd Dec 2008, 10:51 -
Avi dvd player
By imkool in forum DVD & Blu-ray PlayersReplies: 6Last Post: 13th Feb 2008, 21:15
