Results 1 to 14 of 14
  1. Member SE14man's Avatar
    Jul 2005
    Queensland
    Hi there.
    I am back off to the UK for some weeks but was looking for a good piece of software which would allow me to dial in from a PC from england to here to control this PC from over there.
    What software would you recommend? I was looking for something that's quite straight forward.
    So far i know of PC Anywhere, LogMeIn & Teamviewer are these good or are there better?
    Thank you.
    Windows built in remote desktop connection? I use it. Works perfect.
    Moving you to our computer section.
  3. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Agreed - Windows RDP (mstsc.exe) is pretty good. You could also look at some of the VNC variants.
    Read my blog here.
  4. I use Team Viewer pretty frequently with good results. It also has it's own VPN available.
  5. The OP did not state what OS he was using. There are some restrictions for using MS Windows remote desktop on some versions of Vista and some versions of XP.
    From MS.....
    • You cannot use Remote Desktop Connection to connect to computers running Windows Vista Starter, Windows Vista Home Basic, Windows Vista Home Basic N, or Windows Vista Home Premium. You can, however, connect from those editions of Windows Vista to computers running other versions of Windows.
    • You cannot use Remote Desktop Connection to connect to computers running Windows XP Home Edition.
    May 2001
    He did. He is using WinXP Pro w/SP2.
    AFAIK, XP doesn't have the remote software.
    ICBM target coordinates:
    26° 14' 10.16"N -- 80° 16' 0.91"W
  7. Member ranchhand's Avatar
    Oct 2005
    USA-midwest
    Yes it does, Windows Remote Desktop; I have used it several times from Chicago to Florida to help my niece troubleshoot. We both run XP, SP2. Works great.
    May 2001
    What's the name of the executable? I searched for mstsc.* and didn't find anything.
    May 2001
    Found it in START/PROGRAMS/ACCESSORIES
    Apr 2003
    michigan,usa
    Team Viewer is an excellent program!
  11. It looks like Team Viewer is pretty expensive.
  12. Member papakilo's Avatar
    Feb 2004
    Walhalla S.C.
    TeamViewer is free for non-commercial use. I use it all the time.
  13. Member darkknight145's Avatar
    Feb 2007
    Australia
    Logmein works well, use it myself. I have just come back from round the world holiday, had no problems with it from anywhere i stayed
  14. Member SE14man's Avatar
    Jul 2005
    Queensland
    Fantastic guys!
    Thanks so much for all your help.
