Hi, I'm looking for a good laserdisc player that can read PAL & NTSC discs without problem. It's mostly for convertion (Laserdisc to DVD/Blu-ray. Any good model(s) out there that you can recommand me ?
Thanks to answer
Of course you mean a standard def Blu-Ray?
http://www.kiva.org/about -
So what the hell are you looking for....a Laserdisc player?, a Blu Ray player? or a DVD player?
Do these laserdiscs contain movies or programs that are not available on DVD or Blu-ray? It might not justify the time and expense to do your own conversions. It might require purchase of separate PAL and NTSC laserdisc players, as I don't recall anyone making multi-standard units. Check ebay; but moreover, check to see if there are already DVD or Blu-ray versions of the discs you want to copy.
What DVD player is good these days for NTSC and PAL playback?
By b1lanc in forum Newbie / General discussionsReplies: 0Last Post: 29th Oct 2010, 13:56 -
how can i find the region code of a backup and if its ntsc/pal
By korazy in forum DVD RippingReplies: 4Last Post: 26th Dec 2008, 23:10 -
Any good multi-region DVD player that plays PAL/NTSC and upcoverts?
By jtrinc in forum DVD & Blu-ray PlayersReplies: 9Last Post: 13th Jun 2008, 19:12 -
DV recorder/ player for NTSC and Pal ???
By Dash1 in forum Capturing and VCRReplies: 3Last Post: 19th May 2008, 08:50 -
NTSC/PAL DVD player
By jonas more in forum DVD & Blu-ray PlayersReplies: 24Last Post: 9th Jan 2008, 08:40
