I have some 680 MB mpg files that are from a wireless camera and a Siig video capture device. Each file is 30 minutes in length. I want to remove all frames that are the same, except for some noise.
I would like command prompt software that would strip off these frames, leaving segments of video that have a person or animal moving. The camera is stationary and indoors, so there can be whole files with no change.
Is there some software that can do this? If it must be a GUI interface, at least it should work in a batch mode.
Thanks for you help.
There is more to life than meets the microscope.
Is this a security type camera?
Is there constant lighting? If not then any area lighting change looks like motion. Motion algorithms ignore slow light changes and look instead for fast pixel motion changes.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
It is wireless spy cam used as a security cam.
There is gradual change of light during the day. At night it is black when the lights are off so all I need is t remove all black scenes. When the light is turned on there is constant lighting, and the camera is fixed position and fixed focus.There is more to life than meets the microscope. -
I'm not that familiar with current security camera software offerings but most will identify frames with short term object motion.
Header stripping
By NikkiSix in forum Newbie / General discussionsReplies: 46Last Post: 17th Feb 2013, 17:57 -
Stripping from audio, but with a twist.
By Diana (Cda) in forum AudioReplies: 2Last Post: 12th Jun 2010, 14:56 -
Stripping away audio tracks
By Belfaborac in forum Video ConversionReplies: 2Last Post: 19th Feb 2009, 11:06 -
stripping audio
By lou41888 in forum AudioReplies: 7Last Post: 5th Nov 2008, 18:46 -
cd-rom stripping
By marinebc11 in forum MacReplies: 4Last Post: 16th Feb 2008, 08:51
