I was attempting a conversion of a DVD to an avi file using Freemake the other night and for some reason the files always came out slightly pillarboxed. I ended up just doing a straight clone of the DVD but I was wondering if anyone had an idea why I was having the issue with pillarboxing?
Autogk, fairuse wizard and staxrip are much better for good dvd to avi conversion.
Hopefully they'll add a better detection and cropping method soon ... I just set it to 720x576 (pal) and encode using 5000kbps xvid ... then correct and filter in vdub for final outcome
also a bug with tv recordings being converted ... vbr detected after initial conversion but simple to fix in vdub once again.
Freemake Video Downloader: A Tip or Two
By Tom Saurus in forum Video Streaming DownloadingReplies: 0Last Post: 7th Feb 2012, 23:45 -
looking for help from those using 'freemake'
By alphabetagaga in forum DVD RippingReplies: 5Last Post: 14th Jan 2012, 09:13 -
Freemake converter
By gaggymitchell in forum Newbie / General discussionsReplies: 19Last Post: 19th Nov 2011, 18:31 -
Sound Forge puzzler...
By mjl1297 in forum Newbie / General discussionsReplies: 3Last Post: 27th Aug 2011, 09:19 -
Freemake question...
By mjl1297 in forum Video ConversionReplies: 2Last Post: 22nd May 2011, 21:48
