Hi everyone.
I have not long ago bought a HD camera, Canon HF S10. Im having some difficulties getting the files converted with good video quality and correct framerate.
I have testet with sony vegas, when i use the standard dvd template to render, the video quality is horrible compared to how a dvd is suppose to look, but when i try to tweak the template, the quality is still horrible with framerate messed up. I know im doing something wrong.
Now i have tried the trail version of, NewBlue AVCHD UpShift, to convert files to mpeg2, and i was amazed how good the quality was compared to sony vegas.
http://www.newbluefx.com/avchd-upshift.html
Now if the price would have been cheaper i would have probably consider buying it, but come on, almost 80$ for a software that only does is convert.
I was wondering, is there any other free solution which does a similar job, with similar good quality.
or
If anyone knows any good setting on sony vegas to use, so that avchd footage can be converted to dvd with good quality, im all ears. There is definitively a difference between sony vegas and newblue's avchd upshift in video quality. i'll post a link later with video footage converted with sony vegas and avchd upshift to mpeg2(dvd) format to compare.
Thanks in advance.
Avstodvd or multi-avchd should be able to do this for free
Read my blog here.
hi,
i have now tried both, and i cant say i got them working. i get a strange error message when i started the conversion, and one of them gives me an error message when i import the .mts file, and wont convert. any other software which might be easier to understand?
tnx in advance -
It would be helpful to know what the error messages say, as these are probably the best quality alternatives. You could try XmediaRecode or Freemake Video Converter instead.
Read my blog here.
ill post the error message later, at work now. and ill try out the new software as well.
tnx again.
converting avchd (.mts) files to an editable format?
By coady2000 in forum Newbie / General discussionsReplies: 5Last Post: 6th Sep 2010, 00:20 -
software to batch convert m2ts format avchd to mts avchd?
By masterpug in forum Video ConversionReplies: 0Last Post: 14th Aug 2010, 02:06 -
Lumix DMC-TZ10 mts file looks slightly washed out converting AVCHD to mp4
By nhague in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 23:47 -
AVCHD MTS Cutter
By cheerful in forum EditingReplies: 11Last Post: 25th Jan 2010, 21:58 -
AVCHD (*.MTS) to MPEG-2 conversion
By keesio in forum Video ConversionReplies: 39Last Post: 30th Sep 2009, 13:23
