    Dec 2007
    Greece
    I test the sub2divx software and i can say that is awesome! In 3-5 miutes i have avi with subtitles without using virtualdub an waiting for minutes.
    BUT. I want to test my file in my PC before i play it in my dvd player and i can't.
    I have windows 64bit (Greek), cccp+ with Media Player Classic.
    The subtitles does not appear in the MPC but when i use the same file in my dvdplayer no problem.
    Is there any option to activate ot deactivate?
    Thanks in advanced
  2. Member rickydavao's Avatar
    Jun 2007
    Victoria, Canada
    Since you mentioned that you used sub2divx, I'm assuming that you now have a .divx file with xsubs (the divx subtitle format). Apart from the official DivX player, the only other player that I'm aware of that can display these subtitles is VLC. I do know for a fact that neither MPC nor MPCHC with play embedded xsubs in a DivX file. Give VLC (free) a try, you can enable the xsubs through Video -> Subtitles.
  3. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Somewhere on VideoHelp...
    Do you have the DivX codec installed? (CCCP only installs ffdshow, I believe.). sub2divx, as far as I can tell, creates xsubs - a DivX Ultra feature. So, you need either a player capable of reading xsubs, or the DivX codec installed. Are you using a 32-bit version of MPC? DivX only has a 32-bit version at the moment, as I recall.
  4. Member rickydavao's Avatar
    Jun 2007
    Victoria, Canada
    @ Ai Haibara: Just for reference's sake, xsubs are a standard DivX feature (DivX 6 and up) ... all DivX certified players will play xsubs, the player does not have to be Ultra certified. Only chapters and menus in a DivX file are specifically Ultra features.
  5. VH Wanderer Ai Haibara's Avatar
    Jan 2006
    Okay. I usually just deal with them in terms of DVD players, and I haven't seen many of those that support xsubs outside of Ultra-certified players, so I guess I've just come to think of xsubs as an Ultra feature.
  6. Member rickydavao's Avatar
    Jun 2007
    Victoria, Canada
    @ Ai Haibara: S'alright I'm actually kinda surprised you have experience with players that don't handle xsubs ... technically, if it's DivX Certified, it's supposed to handle them. If you can believe it, I still have an original, functioning Philips DVP-642, and it plays them fine. I was very happy when VLC Media Player started supporting xsubs, because now I can create fully compliant DivX files, play and test them without actually having to install DivX, which is kinda neat ...
