Very 1st time with AVCHD Camcorder
Normally along with my Canon A1s, I bring along a borrowed XH-A1 which regrettably acted-up on the past 2 outings so I decided instead yesterday to give it a "rest" and substituted it with a Canon VIXIA HFS-20 which is full frame HD and 100% AVCHD.
The problem is Premiere Pro CS3.2 will not import that footage into the project so i can work on it. It's the standard MPEG-4-AVC/H.264 compression AVCHD video with an .mts extension. This format/codec is entirely new to my experience.
Bottom line: how can this material be successfully converted or otherwise be repackaged to a more compatible format without quality loss that will be recognized as a valid format by Premiere Pro CS3.2 when attempting to import it ? I'd like to see it come out preferably as .m2t footage.
The material was recorded at 25 mbps and will need to be incorporated with HDV footage. That's another issue for a future post.
In order to use this I will need your valuable insight, knowledge and recommendations on how to proceed. All responses welcome.
Thanks so very much.
@canon gl2 guy -does premier pro see the file at all? Does it recognize the mts file? I would verify that your particular version of that program handles that type of avchd. I guess if its a "pro" version it should handle all types. However is this an older version more than a few years old? You might have to bite the bullet and buy a newer version if it deosn't recognize avchd - or you might be able to buy an avchd plug in for the program.
Other than that you could try remuxing the video into either a m2ts or ts file if you know for a fact your program can handle those file types.
You can use winff or tsmuxer to do the converison. It won't alter the video, just repackage it.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
Premiere does not see the file at all and will not export it into the timeline for processing.
Yes, maybe demuxing it will do the trick as the file contains an AC3 audio track.
Thanks for your suggestion! -
Well it seems poisondeathray says that it won't read h264 at all.Originally Posted by canon gl2 guy
If that is the case then perhaps it is time to invest in a new piece of software.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
I have a Canon Vixia also that shoots AVCHD. I had the identical problem in Pinnacle Studio14 Ultra, wouldn't see or import for anything (and they advertised that it would). I finally converted all files to mpeg4 and then they all imported and edited fine, then burned to DVDs. No loss of quality that I could see.
Record DSLR footage straight to my Mac
By Mac_Newbie in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 4th Dec 2011, 00:29 -
Editing AVCHD .mov files straight up in Vegas
By TigerSoul in forum EditingReplies: 11Last Post: 11th Mar 2010, 12:51 -
AVCHD Footage to SD (AVI for Premiere)
By foochuck in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 86Last Post: 12th Nov 2009, 14:39 -
AVCHD footage to Movie
By provehighman in forum Video ConversionReplies: 5Last Post: 25th Jun 2009, 11:55 -
Panasonic DMR-E55-E55S or E55K?1st DVD recorder/1st time posting
By ToeTagged in forum DVD & Blu-ray RecordersReplies: 7Last Post: 19th Jan 2008, 15:33
