Hi guys,
I've recently downloaded Avidemux, and was wondering if it was possible to render clips in HD (720p/1080p on YouTube), and how I could remove the black borders around the YouTube video (they're not in the actual program, so I assume it's just a resolution error?) I'm using Linux Ubuntu if it makes a difference.
If I could get some help or step by step instructions that would be great...
Thank you,
Aeterna
I changed your thread title.
You can output/render your video in HD. If your source isn't HD you can upsize under Filters->Resize...but you wont get better quality by doing this. Use mpeg-4 avc/h264 under the video and AAC under the audio, save as mp4.
Use the Crop filter to remove black border, under Filters->Crop. Use the preview to see how it looks like. After you cropped you might want to resize, Filter->Resize.
Black borders for subs appearing in SVP10, disappearing after render.
By Zamoonda in forum EditingReplies: 20Last Post: 7th Jul 2011, 14:50 -
xmedia Recode how to remove black borders using Crop?? does not work
By pectin232 in forum Video ConversionReplies: 5Last Post: 10th Dec 2010, 09:30 -
HELP ME! Footage was Black in Render and then Turned Black in Timeline!
By GLadius of Sparta in forum EditingReplies: 4Last Post: 16th Aug 2009, 21:03 -
Does anybody know how to convert 16:9 to 4:3 with black borders?
By tuanvn.2007 in forum Video ConversionReplies: 7Last Post: 20th Sep 2008, 03:13 -
Is there an way to crop (remove black borders) without reencoding?
By BlooderButcher in forum EditingReplies: 6Last Post: 21st Apr 2008, 20:52
