[IMG]file:///C:/Users/Faisal/AppData/Local/Temp/moz-screenshot.png[/IMG]
In avidemux I tried to remove 1:22:05 to 1:23:05 but I found audio is not synced.
I tried this wayset point A at 1:22:05 and set point B at 1:23:05 then EDIT- DELETE-SAVE-SAVE VIDEO
plz help me out
thanks in advance
Closed Thread
Try cutting everything after 1:22:05 and saving it as part 1, then reloading the original, cut everything up to 1:23:05 and saving it as part 2. Check that both parts are in sync.
If they are, load part 1, append part 2, and save the new version. Check for sync.
If this fails at any point, try a different version of avi demux.Read my blog here.
One thread is enough. Continue in https://forum.videohelp.com/threads/337260-how-audio-can-be-synced?p=2095662#post2095662
HD PVR - Audio not synced with video
By lacywest in forum Video ConversionReplies: 5Last Post: 29th May 2010, 10:20 -
Video/audio not synced problem. (Avisynth)
By michcio in forum AudioReplies: 0Last Post: 18th Jan 2010, 13:43 -
Tight synced audio + subtitles, poor synced video...
By goodbot in forum SubtitleReplies: 5Last Post: 13th Jul 2009, 23:59 -
video and audio are not synced up
By maniac in forum ffmpegX general discussionReplies: 2Last Post: 27th Apr 2009, 22:53 -
audio and video wrong synced.
By michcio in forum Authoring (DVD)Replies: 0Last Post: 18th Feb 2009, 19:08
