HI, i am a newbienot only to this forum but also to this entire "video editing" concept!
i have seen a lot of posts on the internet say sony vegas is the best of all but some of my friends tell me powerdirector is really good and so is adobe premier!
i have decided to buy any one and start learning video editing!
so plz guide me which one should i buy ? i am very much interested in learning everything about video editing and become a pro in 2 or 3 years. I am willing to spend good amount of time to learn allso plz dont suggest a program good for amateurs!
just the best plz![]()
Sony Vegas seems like a good way to start. It also depends on how often, how much work you plan to do and what you wish to concentrate on. For instance, Virtualdub is free, and you can do PLENTY of video editing with it. Why don't you start with that first? If most of your imports are MPEG-2 (DVD sources), get VirtualdubMpeg2 (not the same as Virtualdub, which does not work with MPEG-2 streams). It has plenty of filters that do different things and will keep you busy for a long time. Plus it's FREE.
Oh and get ready to read a few replies to your question, just mindlessly and aimlessly parroting after each other (in a New Jersey, dunce truck driver's voice) "duhhh, why don't u try avisynth? It duhhhh, ...it's powerful! duhhhh, avisynth! uh...powerful!"
Yet no one will be able to tell you how to use it. -
Why don't u try avisynth???? Hahahaaha
Ok, maybe you can try and google for " NCH VideoPad Video Editor 2.41 [Giveaway] "
They give it for free, but if you are interested.. hurry up, the offer is at the end "Giveaway will end on July 30, 2011"
I tried it 5 minutes ago, and it activated/registered successfully.
Sony Vegas Editing help
By blecap in forum EditingReplies: 2Last Post: 30th Mar 2011, 03:08 -
Editing .264 video from mini-cam in Vegas: Vegas won't read video
By bigass in forum EditingReplies: 3Last Post: 27th Dec 2010, 12:35 -
Sony Vegas + proxy editing - help
By sterankin in forum EditingReplies: 0Last Post: 24th Jan 2010, 15:05 -
Sony Vegas or Editing programs
By nextoss in forum EditingReplies: 2Last Post: 13th Jan 2010, 15:00 -
Sony Vegas editing problem
By tp3813 in forum EditingReplies: 2Last Post: 28th Sep 2008, 05:05
