Hi,
Newbie here,as the title says I am finding it hard to get a solid answer.i use a 560ti oc gpu at the moment and would like to attach it to my full HDTV. My tv has a pc mode via a vga cable with a max res of 1920x1080 with a full aspect ratio. It also has a hdmi mode with a max res of 1080p:1920x1080 with a full and 4:3 aspect ratio. Will I get a good clear picture.I have heard some horror stories about getting the settings right. Th card itself has 2 dvi ports and a mini hdmi port. I assume there are connections that can bought to convert different types of cables. Anyway any help or advice would be greatly appreciated.
Yes, it can be done. It works best if your HDTV has a non-overscan mode. Ie, with pixel-for-pixel mapping of a 1920x1080 source. I have a 46" Samsung 4665 HDTV hooked up to my computer via HDMI. It's perfectly sharp. Just like a giant computer monitor.
Cheers mate,appreciate the quick response. I have to find out if my tv has over or underscan.
HDTV box to monitor
By kanganova in forum DVB / IPTVReplies: 6Last Post: 7th Feb 2010, 01:32 -
Which Monitor for Gaming?
By therock003 in forum ComputerReplies: 60Last Post: 23rd Jan 2010, 16:52 -
Using an HDTV as a laptop monitor?
By Wall-E in forum Newbie / General discussionsReplies: 19Last Post: 6th Oct 2009, 16:34 -
HDTV Monitor Resize
By tombowler in forum DVB / IPTVReplies: 2Last Post: 29th Apr 2009, 14:00 -
LCD TV vs. LCD Monitor for PC gaming
By Xenos80 in forum ComputerReplies: 6Last Post: 13th Feb 2009, 00:01
