Dear,
Please help me.
I want rip my favorite DVD movie into 400mb or less size .mkv file remaining maximum quality to reduce my valuable Hard disk space.
which video movie I or you find on the internet, as like that movie I like to rip.
Please give the instruction with relevant DVD ripping tools.
Any kind of good idea to be very much appreciated.
Results 1 to 12 of 12
use the search box on this site for "dvd to mkv". plenty of info and tools. vidcoder and fairusewizard maybe. but at 400mb quality is going to be low no matter what you use.
Bro, I like to do Net (download) quality ripping in low file size.
Now I use FairUse, But its file size & Resolution auto adjusted to each other.
If I set file size bellow 700mb, its resolution adjusted automatically to short.
I just want to rip DVD movie in download quality & size...................
You can see the movie quality in which I meanLast edited by johns0; 29th Jul 2011 at 17:01. Reason: please do not link to warez sites
iqbal88 - You can't actually "rip a DVD into an MKV file". It's 2 steps. The first is ripping - getting the movie off the DVD. The 2nd step is converting to MKV or whatever. We have been known at times to be unkind to newbies who ask about ripping to various formats when such is actually impossible as it's a 2 step process - rip then convert. I'd encourage you in the future to use the correct terminology.
As aedipuss points out 400 MB or less is not going to result in anything that most of us would consider to be "maximum quality" but perhaps you are not very fussy and such is OK for your needs. Maybe you would find Handbrake to be useful, but I've heard reports that it may not behave correctly when asked to produce files as small as what you are looking at.
Hard drives are cheap. I don't know where you live but in most developed countries it's pretty foolish to worry about disk space when you can just buy another drive. -
ThanX My Bro adipuss & Jman98 for both your kind suggestion.
But till now I m in a ambiguous atmosphere.
I have not yet get my Question ans properly
I Just want to rip Net Quality [Maximum] Movie in low size (350mb to 450mb) to upload
Now I use FairUse, It work good & so easy. But its file size & Resolution auto adjusted to each other.
If I set file size bellow 700mb, its resolution adjusted automatically to short range of pixel.
n.b: FairUse handle mkv in tough way, & processing in too much time consuming -
If you have the dvd ripped and on the hard drive (or have it decrypted with AnyDVD in the background), you can use Handbrake and convert to H264 video in an mkv container at 400mb size.
Start Handbrake, set output container to MKV, click on the Video tab and set Quality to Target Size, set target as 400mb. Put a check mark in 2 pass encoding box. If you want AAC audio, it will convert to that in default settings. If you want something else, click on the Audio tab and set it to whatever you need.
Its not too hard. Don't know if you'll like the quality of the output however. It should be similar to xvid at 700mb. -
I agree with u bro "ripping takes a long time" there is no controversy with u.
But my question is here "How I can rip DVD or BLUE-Ray movie in net means download quality. i.e which movie we can download from internet like as various forum or from torrents?"
I like to do just that.
you can check-out a movie download site and their movie Quality & of course size is a matter.
& another think you should mind that, "to upload a movie file on internet file size is a big concern"
Link
I think I could tell you what is my wish.
And Thank You Bro for your nice remarksLast edited by Baldrick; 14th Aug 2011 at 13:13. Reason: Warez link removed
MKV guide, Play MKV, MKV to AVI, MKV to DVD, MKV to MP4, MKV to Blu-ray
By Baldrick in forum Newbie / General discussionsReplies: 55Last Post: 29th Jun 2012, 12:19 -
Rip DVD to .MKV
By adjaq in forum Video ConversionReplies: 19Last Post: 12th Mar 2012, 20:16 -
DVD Subtitles to Bluray rip in mkv
By Flarup in forum SubtitleReplies: 1Last Post: 11th Nov 2010, 18:30 -
Is it true we can rip the WHOLE dvd to mkv?
By reapur in forum DVD RippingReplies: 4Last Post: 24th May 2010, 19:43 -
Tip To Rip DVD To MKV
By dgarcia11087 in forum DVD RippingReplies: 4Last Post: 17th Mar 2010, 04:29
