Hi everyone...
How should you encode this to SVCD ?
Aspect Ratio: 16:9
Frame Rate: 29.97 fps
Video Type: FILM
Frame Type: Progressive
Should I deinterlace this ?
I want to burn my SVCD and watch it on TV..
Useing Tmpgenc 2.53..
Please help !
THX
/Stisse...
Hi!
The best advice I can offer is to suggest that you check out the many superb guides that are on offer at this site <-- left nav bar <--
Then, once you've learnt all this great site has to offer, do us all a favour and donate a few bucks to the cause!
Have a good one ....... Sue xxx
this setting is not indicative of the source framerate....
this actually results from you NOT choosing FORCED FILM in dvd2avi...
however, because the source video is FILM, Progressive...you SHOULD turn on FORCED FILM in dvd2avi....you'll then notice that the framerate has changed to 23.976 fps
also...remember that 16:9 aspect ratio because you will need this info to enter in source aspect ratio in tmpgenc before you can encode properly
also....do not "de-interlace"....only "de-interlace" if you see any horizontal lines in your rip...the best setting i've used is double (adaptive)
how to encode?
By inject0r in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2012, 12:12 -
How to encode 3D STEREOSCOPIC to 2D
By riky in forum User guidesReplies: 0Last Post: 17th Dec 2010, 06:17 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 13:09 -
Why do I have to Encode?
By gilamran2 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2008, 04:29 -
Re-encode to HD
By lotsill in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 11:03
