Hi guys , Ive just bought a new pc that has a WIN TV DVB-T card (thats what it says on'my computer' settings) installed.
I understand I can plug an aerial into it to receive TV pictures, but can I somehow hook my VHS video recorder to it , to copy old VHS tapes to my pc ?
If so , what cable do I need ?
Thanks for any help .
				Results 1 to 10 of 10
	Start -> Run -> type "devmgmt.msc". Device Manager will open, look for your device in "Sound, video, and game controllers". Tell us what it says. Alternatively, look up your PC's model number online to see what it says in the specs about your card.
	Thanks for the quick reply vaporeon. When I check the device manager , it shows as Win TV DVB-T (Model 133xxx)
 The pc is a HP 5653. Not sure if the card is fitted as standard, as it has a graphics card as well.
	Can't find any info on that model; it's a Hauppauge tuner but it appears to be HP-specific as their site doesn't list it. Any inputs on it besides aerial?
	Note that a DVB-T card doesn't necessarily have the ability to convert analog video to digital. The DVB-T broadcasts are already digital. A search for "Wintv DVB-T model 133" turned up this post where I guy mentions having an HP Pavilion Elite MPE 590UK:
 http://webcache.googleusercontent.com/search?q=cache:IP88isTCwk4J:www.hauppauge.co.uk/...www.google.com
 Searching for "HP Pavilion Elite MPE 590UK" Turns up this page:
 http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c02682170&lang=...odTypeId=12454
 Where it is indicated:
 TV Tuner... Hauppauge DVB-T PCI Express... A 10-pin header on the card provides additional S-Video, composite video, and audio inputs for multimedia connections on the front of some PC cases.Last edited by jagabo; 29th Jul 2011 at 08:12.
	There are 2 'sockets' on the card ... one where I can plug an aerial type connection in (labelled 'tv') , and another small circual port labelled 'ir in'.
	IR in is probably for an infra red remote control sensor. If that's all the device has you're probably out of luck as far as VHS capture is concerned.
	Ah well.. I assume I can plug a normal tv aerial into the socket and record TV programmes ?
 Back to plan b then... either a PCI Capture card, or buy one of these external devices that plug into you rusb socket.
 I will have to see how much either cost as I dont have that much VHS footage to copy anyway.
 Any suggestions guys ?
	There is one possibility left: try the RF output from the VHS deck. See if the device will capture from that. If not, you can only capture DVB-T digital broadcasts.
	Thanks for help guys.
 I have borrowed my mates video camera which allows for analogue in / digital output , and am capturing it happily to my pc .
  [VHS conversion] Sound Card, Video Card?By bessiecat in forum Capturing and VCRReplies: 6Last Post: 26th May 2011, 14:02
  Capturing VHS with ATI TV Wonder HD600 PCI cardBy CamaroDMD in forum Capturing and VCRReplies: 12Last Post: 17th Jun 2010, 08:58
  Capturing VHS to ALL-IN-WONDER CardBy Smack2k in forum Capturing and VCRReplies: 6Last Post: 2nd Dec 2008, 10:20
  From VHS to Capture Card to Capturing SoftwareBy TV107 in forum Capturing and VCRReplies: 1Last Post: 9th Nov 2008, 19:35
  Qaulity Capture Card for VHS-DVD & Computer TV Viewing/CapturingBy RubicksCube13 in forum Capturing and VCRReplies: 1Last Post: 11th Nov 2007, 09:00
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
