  1. I have read many forum posts on how to covert .ts from a Humax pvr to a more widely compatible format and so far this is the solution i have come up with:
    . Origional format is .ts (m2v/mp2)
    . Demux with ProjectX.
    . Remux the audio and video with ImagoMPEG-Muxer. (this solves sync issues in avidemux)
    . Crop the ads with AVIDemux and save without changing the format.
    . Use AutoGK to clean up(deinterlace/crop border) and encode to avi(XviD/Mp3)
    While this works fine it is a bit of a chore. Can anyone suggest an alternative solution or (free)software to slipstram this process?
    Thanks.
    Mar 2009
    HUMAX VIDEO FILE COPY
    Use the USB outlet to copy the video file to a memory stick or an externa hard drive
    formed in FAT 32 . ( follow the " Opt+ " button on the zapper). A 1 hour video takes around wenty minutes
    to copy .Plug the medium to a computer and copy the file into it .
    Now you can process it to suit your needs . The XiliSoft and the WinFF converters work for
    me then you can use the Sony Vegas editor . I have not experimened to find the best software
    and proceedures .
    I believe you can also transfer the files across the LAN . There is at least one good Humax
    user group in english on the net .
