Okay, so recently I've taken a stab at burning various DVDs for my friends/family, burning old videos I'd like to backup in case I lose my external HD or anything like that, and my problem is that when I've burned and verified the video, I play it to find the audio/video a second or two out of sync. I'm just going to list out the process I go through when burning DVDs, start to finish, in the hopes that I can get advice how to improve it.
1. Obtain video, generally in .avi format
2. Run it through Avidemux, a program that rebuilds frames and allows me to change the audio to MP3(lame) and change that from VBR to CBR if needed, in the hopes that that was the cause of the A/V being out of sync. (I guess it wasn't) Then I save the changed avi file.
3. I open that file with DVD flick, which as I understand it converts it to vob. I tell it to verify disc after burning, and if I intend to make multiple copies, make an ISO image as well.
4. After it converts it, it opens ImgBurn and burns it to disk at 8x write speed (On my Sony DVD+R single layer 1-16x 4.7GB DVD)
5. The drive pops out, and a window appears informing me to push it back in so it can verify it.
After it's done that, I view the DVD and the audio is ~1 second ahead of the video. I know it's not the .avi file that's out of sync, so I have no idea why it does this - half the time it does, and half the time it doesn't, and on occasion it's fine for a time then the video glitches and it lapses into the same problem.
For all I know there's a beautiful guide somewhere explaining everything in terms I can understand, but I couldn't find it. Any help you guys can give me would be greatly appreciated, especially if you explain it in terms I could understand.
	imgburn only burns exactly what you give it, so don't even think that's the problem. try simplifying your method. either buy convertxtodvd or try using avistodvd. and just importing the original files. --
	Alright, I'll give ConvertXToDVD a shot - do you know if VBR vs CBR avi format matters at all in that program, or in any DVD burning software for that matter? Thanks for the suggestion
  Flash .flv video out of sync (original video is perfect with double audio sBy TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13
  MKVvextract stretches extracted audio/Audio not in sync with videoBy cgo in forum Video ConversionReplies: 16Last Post: 15th Jan 2012, 18:15
  An app to visually sync audio to video similar to Subtitle Edit visual syncBy cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54
  Odd breaks in video/audio authoured with DVD Shrink 3.2 & ImgburnBy bahjan in forum Authoring (DVD)Replies: 1Last Post: 1st Sep 2010, 14:46
  Nero vs ImgBurn: Why is ImgBurn preferred?By usually_quiet in forum Authoring (DVD)Replies: 31Last Post: 28th Aug 2010, 18:47
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
