Sorry if this sounds newbiesh, but how do I decide which aspect ratios to use? I use TMPG Enc to make mpg files for XVCD's of movies in AVI format. Some of them have resolution like 576 by 320 and some have 512 by 384 when I get them. I know that 1:1 ratio should be used when width divided by length gives 1.3333. And that 4:3 should be used when it gives you something around 1.5. I'm right, right?
When should you use the 16:9 ratio? When the division gives you 1.8? When should 2.11:1 display used? Also, these aspect ratios are what you put into the source aspect ratios in the settings dialogue, right? And if you want to watch the movies on a standard TV, fullscreen, you should put the video aspect ratio to 1:1 in the setting dialogue, right?
Thanks in advance if you read this far and answered my questions.
Oh and if it makes any difference, the resolution I use for the output MPG is 720x480
Multiple Aspect Ratios on One Disc
By gorcq in forum Authoring (DVD)Replies: 7Last Post: 20th Dec 2011, 22:35 -
Display aspect ratios in MPEG-2
By DRP in forum EditingReplies: 4Last Post: 4th Jul 2010, 20:46 -
iMovie and aspect ratios
By sphinx99 in forum MacReplies: 3Last Post: 11th Mar 2010, 00:18 -
multiple aspect ratios on one DVD?
By towtruck in forum Authoring (DVD)Replies: 11Last Post: 7th Jul 2008, 03:58 -
Aspect Ratios
By gayclarke in forum Authoring (DVD)Replies: 3Last Post: 15th Sep 2007, 16:13
