  1. Hi, I've been doing some research into the best program to burn Data on a Double layer disc. My research has only come up with ImgBurn. I don't want burn a single ISO, I want to burn multiple files contained within folders. The only program I that I found for this is CD Burner XP, any other recommendations ?
  2. Banned
    Freedonia
    ImgBurn lets you burn data discs. You can select folders and everything inside the folder, including the folder itself, gets burned to the disc. Make sure though that the option to recurse into subdirectories is turned on
  3. Perfect. Thank You
