Can anyone recommend software that will allow you to add text fields to multiple video frames.
i want to be able to process thousands of frames at a time...not have to do one frame at a time.
This is what's knowns as "credits", "subtitles", etc. Look in the Tools section on the left re: subtitling software and you find a bunch. Many can do a text file import that you then "time" (aka "sync") to your video.
edit: some will do them only as an overlay (soft subs) but some will allow hard subs. And any NLE worth it's salt can do credits titling.Last edited by Cornucopia; 26th Jul 2011 at 17:37.
decoding mpeg video into frames say I,P,B frames
By abeer in forum ProgrammingReplies: 44Last Post: 6th Oct 2012, 08:24 -
Text Video
By alestormdk in forum EditingReplies: 5Last Post: 12th Oct 2011, 21:13 -
Read text create audio and convert text to synced subtitles in mp4
By Philip Lean in forum SubtitleReplies: 1Last Post: 25th Feb 2010, 08:54 -
looking for good OCR software that will convert text in jpg to regular text
By jimdagys in forum ComputerReplies: 6Last Post: 27th Jun 2008, 10:38 -
C# code to save text from listbox to a text file -- SOLVED--
By freebird73717 in forum ProgrammingReplies: 2Last Post: 2nd Sep 2007, 15:50
