Results 1 to 30 of 40
    Jul 2011
    Bristol
    Hello,
    I use Fraps to record videos from games(world of warcraft) with settings 1920x1200 @ 60 fps. I edit it in Sony vegas pro 10 64 bit. Now problem is how i should render it in vegas to have best material to use it in staxrip? What settings i should get in staxrip/vegas to get best quality in the end? I will sow examples:
    Mine last best quality which i get:
    http://www.youtube.com/watch?v=fT_Ma8vl1fg
    And here is quality which im aiming for(example):
    http://www.youtube.com/watch?v=O9qSBwbw_9M
    What codecs and what settings i should get to be able to upload in youtube to get best hd quality?
    Oct 2005
    666th portal
    you can output mp4 directly from vegas. choose the sony avc encoder and the internet 1920x1080 preset. you can either crop your video to 1080 or change the encoder settings to output 1200(youtube will re-encode to 1080 with black bars on the sides). choose a fairly high bitrate 8-10 mbps should do.
    edit - it will output 30p not 60p which youtube wouldn't deal with nicely anyway.
    Jul 2011
    Bristol
    I did recommended settings and still no improvment from quality i get last time on youtube.
  4. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Render your project to Frameserver for RIPBOT264 (check this link: Frameserver to Vegas 64bits.)
    Medium Quality:
    For Youtube-480p I use 2000brt
    For Youtube-720p I use 4000brt
    For Youtube-1080p use 6000btr
    High Quality:
    For Youtube-480p I use 3000brt
    For Youtube-720p I use 6000brt
    For Youtube-1080p use 9000btr
    Jul 2011
    Bristol
    Thank you for help and this is what i get from ripbot+fs:
    http://www.youtube.com/watch?v=BeKylROlV04
    Please tell me if i can get better quality than this?
  6. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Sorry man, I forgot to say something.
    To render in 30 frames, but need to disable resample. Look my settings:
    On timeline, click with mouse button 2 and:
    Select like it:
    Your video is very sharp now (no more blend/blur video).
    In RIPBOT264 go to PROFILE ..., click and config like screenshot.
    Now your encoder is very sharp too.
    Upload to YT and reply to me...I like view 1080p videos hehehe
    Claudio
    Jul 2011
    Bristol
    This is what i get from youtube:
    http://www.youtube.com/watch?v=nnDczZFsD2U
  8. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Very good.
    Increase your bitrate.
    From 1080p on YT, 5000brt is not good.
    Bigger bitrate source file is more quality in YT conversion to MP4/FLV.
    Jul 2011
    Bristol
    where to do it?
    Jul 2011
    Bristol
    Very good.
    Could you tell me where i should change this bitrate?
  11. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Very good.
    On Youtube conversion?? No way man. Its a automatic. But source with higher bitrate file, more bitrate youtube will use in conversion.
    Claudio
    Jul 2011
    Bristol
    I get it but where i should change this bitrate? RipBot ? Where are this settings? Could you paste here some screenshot?
    Jul 2011
    Bristol
    Cauptain there is any chance you could tell me where i need to change this bitrate?
  14. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Hi wgizmo,
    Upper only bitrate in ripbot: select 2 pass and use 12.000/14000 to 1080p.
    Claudio
  15. I'm aswell looking for the best rendering settings with having frpased at 1920x1200.
    I'm only using vegas tho. But for some reason I can't change the height to more then 1080, it won't go to 1200....
    So I get very annoying black bars when done rendering.
    If you could help me Cauptain would be a lifesaver, pulling my hair out at the moment going crazy... feels like I've tried everything
    Jul 2011
    Bristol
    Just fallow thats what he wrote and you gonna be fine.
  17. Originally Posted by wgizmo View Post
    I will do that but would like to do it just in vegas if possible and it would be possible if I could change the god damn resolution to more then 1080
    Thanks tho I'll see if you tips helps out
  18. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    doesn't really matter if vegas adds the bars. youtube would do it anyway and not as well, 1920x1080 is as big as youtube goes.
    but if you really need to vegas will render to 1920x1200. render with mainconcept avc and create a custom template.
  19. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Sorry tunnland but in my knowledge is impossible, at moment of course.
    I use Vegas HD 11. No way.
    Claudio
  20. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    oh well, it was the op that said he was using vegas pro 10, which does work.
  21. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Yes. Because this I listed Vegas HD 11. This error is common in Vegas HD series.
    Claudio
  22. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    you can use other 264 encoders. vidcoder isn't hard to set up and will export 1920x1200.
  23. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    But in Vegas 10 he can use framedebug and use any 264 encoder (resize to 1920x1200, of course).
  24. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    he already said he doesn't have vegas pro 10, he has vegas studio, i don't think debugmode frameserver works with it.
    p.s. you can knock off using the annoying bold now. it will just get you ignored like using ALL CAPS.
  25. Originally Posted by aedipuss View Post
    Go get 'em, aedipuss. I've wondered about all that bold-faced writing myself. But Cauptain is a helpful fellow and shouldn't be discouraged from posting. I agree that he should just tone it down a bit.
  26. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Sorry aedipuss.
    That's just habit. I wore BBS in the 90s and it could not differentiate between posts.
    With the birth of the forums, the first thing I did was create a visual identity and it came in the form of writing ever bold.
    Check this, you will see all the forums I go to write equal. But I respect all opinions. Included yours.
    I will change this.
    Claudio
  27. Member
    Jul 2009
    Spain
    Yes, as I said some time ago:
    Originally Posted by Gavino View Post
    Cauptain, no need to shout.
    If all your posts are in bold, what are you going to do when you need to emphasize a point?
  28. So I havnt been able to try your tips out due to being on holiday. But if I use these settings in vegas(I'm using Vegas Movie Studio HD Platinum 10 and I'm on 32-bit):
    I get this as a result:
    Those black borders are really messing with me.
    So I've downloaded Ripbot (not frameserver) and have used your settings in Ripbot.
    This might be a really dumb question but do I use my raw footage first in Ripbot and then edit it in Vegas or do I use my edited and render sony avc(mp4) file in Ripbot?
    This is what I want to achive:
    http://www.youtube.com/watch?v=6yMsSU6OVEs&feature=channel_video_title
  29. Lone soldier Cauptain's Avatar
    Jan 2006
    Brazil
    Easy my friend.
    To skip black borders make this:
    On video in timeline, click with mouse button 2 and select properties:
    Select like it:
    Relaxe man, its a normal doubt.
    First you edit the file in Vegas (adjust colors, effects, texts...) and save in AVI (RAW mode) Uncompressed or using UT Video codec or Lagarith codec.
    After it open your RAW file in RIPBOT and encode with your desired settings. To last upload to youtube and post here for look the result.
    Claudio
  30. Thanks a bunch man! Really helpful, the side borders disapeard but the top one is still there due to footage being recorded in x1200 and project settings x1080. So I guess there is no way to make it like the video I linked with Sony Vegas? Do you know of any other editing programs that it would work with?
    I'll upload the one I got to youtube in a while for you to see. The uncompressed avi file is 80gb :P
    EDIT: Hmm when I'm trying to open the enormous file with ripbot I get this error:
    DirectShowSource: RenderFile, the filter graph manager won't talk to me (C:\temp\RipBot264temp\job1\getinfo.avs, line 2)
