thanks
Results 1 to 11 of 11
virtualdub 1.3c
www.vcdhelp.com/virtualdubaudio.htm -
i tried, but not success
File=>Open Video file=>get error message (No video stream found.)
my *.asf is auido file, what can i do? -
dbPowerAmp will do it - any asf or wmv
find the link in the 'Tools' secionyour pal,
Stinky -
dBpowerAmp Music Converter can't open *.asf file, how to fix it?
he only support following file format:
Cda, mp3, mp2, wav, wave, mpg...............
i haven't see *.asf in the list -
it does handle asf files
you just have to download and install the extra codec pack
then it will do asf
so it's install dbPowerAmp then install their codec packyour pal,
Stinky -
yea thats a tough one - not sure what happened - it's a great product but I dont know where to find it now
Ok go to http://www.filemirrors.com search for dbpoweramp
it looks like there are enough mirrors that all the extra packs are available -- not sure which is which - so your going to have to do some tiral and error
try this one (found on filemirrors.com)
ftp://ftp.ntust.edu.tw/Win95/yesterday/mediaencod/dBpowerAMP-codec-wmav8.exeyour pal,
Stinky -
You can also use Konvertor. It has a nice 30-trial version. Just search for it at cnet, dowload.com, or zdnet.
How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
How to Extract /Convert RMVB Audio Files to MP3 or WAV?
By devilcoelhodog in forum AudioReplies: 6Last Post: 28th Dec 2011, 10:07 -
convert dts 5.1 wav to ordinary mp3 etc.
By flannob in forum Newbie / General discussionsReplies: 2Last Post: 15th Sep 2010, 05:02 -
Convert MP3 -> WAV, Copy to HD and RIP
By ctdvd in forum AudioReplies: 4Last Post: 23rd Jan 2010, 06:32 -
need convert from audio caset to wav or mp3
By assi in forum AudioReplies: 6Last Post: 5th Nov 2008, 19:07
