My Cable box is by my new DVD recorder but my two Tvs are not (logistics dictate where the TVs are). TV One has composite and component connections; TV Two has only composite connections but with a mini plug/jack on its end.
The cables that came with the devices are too short to reach from the DVD to either TV. Are there cable extenders for composite/component cables? If so, is there a difference in the output using extenders? Or does it degrade the signal and I should just try to buy long (10') cables instead? (assuming that they have a long RCA->mini-plug cable for TV Two).
Thank you
Either will work for composite video but I'd buy single cables of correct length. Check out monoprice
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10241
You may need to build a custom RCA-Miniplug if you can't find it at monoprice.Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
Thanks edDV. They have the cables except for the RCA -> Mini. I found that one on B&H though it's an angle plug - it should be OK, though.
I appreciate your help. -
There will be no difference in audio or video quality whether you use extension cables (along with your existing cables) or a new longer cable (unless one of the cables is bad). But it's cheaper and easier to find normal long A/V cables. For RCA/mini pin plug audio use one of these:
http://www.amazon.com/Cables-Go-Stereo-Female-Adapter/dp/B000J1H4VI/
And, at 10 feet, there's no reason to spend more than US$10. US$100 cables won't give a better picture or sound. -
Thank you, Jagabo, for your help. And that adapter likes look just the thing I need, at least for the audio.
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 00:17 -
Hauppauge 1212 with 4 USB Active Extension Repeater cables
By mail2tom in forum Capturing and VCRReplies: 1Last Post: 22nd Mar 2010, 19:52 -
dv cables
By rizvi in forum DVD & Blu-ray RecordersReplies: 2Last Post: 24th Mar 2009, 02:44 -
dv cables help required
By rizvi in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 18th Mar 2009, 03:05 -
HandyCam Cables?
By Guiboche in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 8th May 2007, 15:50
