I have sony vegas pro 9. I was wondering for a football highlight video with slow motion and other little things what is better for rendering. CBR or VBR(two pass)? Thanks.
Standard def video.
Results 1 to 9 of 9
VBR is more efficient in terms of quality vs size (the tradeoff is the extra rendering time). Though the difference probably won't be so big with football highlights. If you're putting less than an hour on a single layer DVD you might as well use CBR and save time.
Some key questions.
1. Source format
2. Length of highlight video
3. Destination. DVD? Youtube? Blu-Ray?Recommends: Kiva.org - Loans that change lives.
http://www.kiva.org/about -
When I make an AVI copy that I put on the computer to put over our school channel I have a question about rendering. What would give me a little better quality or would it even? Interleave every frame or every .250 sec default?
When audio and video are multiplexed within a file you have a little video, a little audio, a little video, a little audio, etc. Interleaving effects the size of the video and audio chunks.
vs:1 frame of video
1 frame's worth of audio
1 frame of video
1 frame of video
4 frames of video
4 frames' worth of audio
4 frames of video
4 frames of video
No Audio With Render
By wingspar in forum EditingReplies: 1Last Post: 8th Oct 2011, 17:22 -
sync without render?
By mrjoetoff in forum Newbie / General discussionsReplies: 0Last Post: 23rd Aug 2009, 11:04 -
What quality do I render to?
By seven1970 in forum Newbie / General discussionsReplies: 6Last Post: 22nd Feb 2009, 16:59 -
How to render as MPEG2 at 2.35:1
By Cunhambebe in forum Newbie / General discussionsReplies: 40Last Post: 30th Mar 2008, 13:52 -
capture without having to render
By sfischer in forum MacReplies: 1Last Post: 6th Mar 2008, 13:09
