This is a follow up to the last post I did about using an H264 file to edit it. I was having a problem with dropped frames when I did a dissolve or put up a graphic. The work around I found was to export it to Quicktime with no rendering. OK, problem solved...not quite! Now I notice that the audio is a bit off...at the beginning of what I am editing it's 26 frames off...later in the video it's 2.5 seconds off...so it keeps adding to it the further in it goes! And since I am editing a dance recital I really can't be off by much because people will notice.
I have tried every trick in the book I know, tried exporting to every file format I know, still having the same problem. Can anybody out there please enlighten me how to stop this audio sync issue?
T
if you go back to the original h264 file, the audio is correctly in sync, right?
if you go back to that file, and export it to DV Stream with the audio Locked
from Quicktime Pro, how does that DV Stream file then playback? Is audio
sync then enabled? if so, then import that DV Stream file into your NLE
and then add your dissolves..."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User -
Hey Terry, actually this became such a headache I ended up just syncing up the audio up manually. Wasn't all that bad once I got the rhythm of it down. I even went to my local Apple Store and showed a Final Cut Pro teacher what was happening, and she was stumped.
hmmm...glad you got it fixed Huntr.
Urban Mac User
Syncing audio with d2v
By Norio in forum Video ConversionReplies: 8Last Post: 23rd May 2010, 02:07 -
Syncing and adding to audio?
By architectofpain in forum AudioReplies: 2Last Post: 20th Jun 2009, 03:03 -
editing/syncing audio
By angryassdrummer in forum EditingReplies: 3Last Post: 1st Sep 2008, 05:20 -
audio syncing
By projecttemp in forum AudioReplies: 3Last Post: 9th Apr 2008, 22:11 -
audio syncing issues
By anap in forum Newbie / General discussionsReplies: 2Last Post: 19th Dec 2007, 05:11
