I have 5 files the extensions are 1.mp4 2.mp4 3.mp4 4.mp4 and 5.mp4
I tried hjsplit to join it but i could not I have avidemux but I dont know is it possible throgh it or not or how?
plz help me
thanks in advance
				Results 1 to 16 of 16
	In Avidemux select video=copy, audio=copy, format=mp4.
 Click on File>Open and select 1.mp4 then click on File>Append and select 2.mp4 then 3.mp4 and the rest of your files.
 Click on File>Save>Save Video to save your output file and give it a name and extension of mp4 such as [final_file.mp4]
	Question:
 Are exact copies of your MPEG files guaranteed? Because although I pick copy for video and audio, when you're saving there's still an encoding process. Is this re-encoding or actually copying your exact file without re-encoding?
	Wait, so is it re-encoding or is it not? And if it is, then what is the purpose of the "copy" option?
	My videos are vob files ripped from my DVD set. They're 30 minute episodes from a series, so I'm trying to combine 3 episodes as 1 entire file to burn on a dvd. I don't want to re-encode them, just combine them and burn them on a DVD
	My rule of thumb was:
 ONE audio stream....no 5.1 audio. That worked every time for joining titles.
	These answers, as much as I'm sure you all mean well, have absolutely nothing to do with what I'm asking. I don't think I've explained myself clearly so I'll just start all over. Forgive me for not being clear earlier:
 Once upon a time, I put a DVD in my computer and ripped a few episodes AS-IS, which became .vob files.
 I chose 3 of those .vob files (episodes) and loaded them into Avidemux.
 The goal was to join 3 of those episodes (both audio and video) into ONE SINGLE STREAM for authoring and burning. I did not wish to re-encode.
 I want to just append them and save a copy of them AS-IS (that means NO re-encoding), and save them, both audio and video AS IS for authoring and burning.
 My question is: When I choose the COPY mode in Avidemux for saving, is it truly saving both, audio and video AS-IS, or is it doing some type of re-encoding that I'm not aware of?
 The resulting quality looks exactly the same but the window says "encoding" while it's saving.
 Am I kinda, sorta clear now?
	In copy mode, avidemux doesn't re-encode. (Not even a little - it doesn't smart render a few frames with MPEG2 even if you had performed edits)
 If you look at the speed when it's processing, that should give you another clue: Re-encoding would be much slower than stream copying
	Hi all!
 I've got Windows7, Avidemux 2.6.8., and a problem with joining videos.
 I have videofile01 and videofile02, and i want to join them together.
 I open vf01, then use Append, choose vf02 and avidemux crashes. It says "Crash. Press Ok to built crash info".
 But no info after "Ok", it just closes.
 Could anyone help me to understand - why?
 I tried to join them otherwise: opened 02, appended 01 - and it worked.
 So, as i understand, formats are all right...
	This is right. Encoding all the parts here takes 1h40, but the joining of the parts takes 20m. And takes this time because the parts are on a USB device. Differently from the encoding, joining does not takes 100% of the CPU, so the cause of this delay is the speed of the USB.
  How to use Avidemux to join MP4 ?By Mue in forum Newbie / General discussionsReplies: 1Last Post: 7th Oct 2010, 11:07
  how do i edit .js files for Avidemux?By KneeRow in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2010, 17:20
  what is the correct way to join videos in avidemux?By sgbd in forum Video ConversionReplies: 4Last Post: 3rd Sep 2010, 10:03
  combining VOB files with avidemuxBy majax79 in forum Newbie / General discussionsReplies: 2Last Post: 20th Jul 2010, 02:17
  Avidemux + YAMB couldn't join my .mp4 files - help!By tigerb in forum Newbie / General discussionsReplies: 8Last Post: 14th Jan 2010, 16:33
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
