    Jul 2010
    ok my question is whtch software is good for DVD to xvid ripping.
    Quit simple is good.
    it should be able to have 2pass options and also copy audio option so I can have the original audio and not convert it to MP3 or something.
    I still want to have the 5.1 audio.
    Also auto detect size and keep aspect ratio if size is changed.
    Auto Crop and stuff.
    I like Handbrake but it is for MKV and MP4. so something like Handbrake but for xvid.
    The older handbrake does xvid but it can detect size good if you want some other size.
    if you want to change it so it have 720xSomething in size.
    also good if it can open and iso file too and not only the video_TS folder
  2. If you want easy, AutoGK.
    I would do it manually with DgIndex, AviSynth, and VirtualDub.
    Jul 2010
    ok thanks
    anyone else that have soemthing else. Like a handbrake GUI style but with xvid support.
    Jul 2001
    You could try Xvid4PSP. Haven't used Handbrake for a little while (or any converter in awhile for that matter, mostly straight to hard drive for last few years ... disk space is just to cheap for the time spent converting) but thought for sure it had Xvid support.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
    Jul 2010
    the reson for xvid is to have support in the DVD player. and I have space to have it on so mkv makes better quality with the same bitrate but I can higher the bitrate for xvid so I still keep the quality. so vidcoder with handbrake 0.9.3 support would be nice or a Handbrake 0.9.5 GUI style but for handbrake 0.9.3. yea they have a old xvid but works great. the only thing I missing from handbrake 0.9.3 is the keep aspect ratio option so I only set the width then it automatic set the height.
  6. Again, AutoGK and Xvid4PSP supports everything you asked for.
