Hi all. I'm a relative newbie and probably know enough to make problems for myself... Here's my issue that I'm hoping someone might be able to help with.
I use a TV tuner stick with my PC to record shows in Windows Media Center. I then convert from .wtv to .dvr-ms using WTV Watcher, scrub it automatically with Lifextender to cut (most) commercials. That leaves me with an .dvr-ms that I then use DVRMStoMPEG to convert to .mpg.
Everything up to DVRMStoMPEG is automated, so it's not as bad as it sounds.
Since these files are huge I've been running them through RipBot264 to crunch them into manageable h.264 .mp4 files. I get the end result I'm looking for with every show but one, the F1 races.
If I play the original .wtv file, or the .mpg file, the audio is fine through the whole file. Commercials and during the actual race. VLC, WMP, the audio is there.
But when I set the file up in RipBot and select Preview, I get audio during commercials and *no* audio during the actual race. Sure enough, if I convert it anyways, there's no audio during the race, but I get to hear all the McDonalds commercials I might want.
RipBot seems to not like F1, because every other show I've recorded to date is just fine.
I've figured out that if I run the file through Windows Movie Maker and convert it to a .wmv (which the audio is just fine in), then convert it in RipBot, the audio is just fine. But this is an extra few hours and an extra step I'd like to cut out of the workflow.
Can anyone tell me what the issue might be with RipBot picking up the audio for certain files? I've attached the information about the file from MediaInfo, which is in the RipBot Tools folder. Thanks for the help.
Tim
General
Complete name : F1 Germany Grand Prix_2011_07_24.mpg
Format : MPEG-PS
File size : 16.2 GiB
Duration : 3h 3mn
Overall bit rate : 12.7 Mbps
Video
Format : MPEG Video
Format version : Version 2
Format profile : Main@High
Format settings, BVOP : Yes
Format settings, Matrix : Default
Format settings, GOP : M=3, N=12
Duration : 3h 3mn
Bit rate mode : Variable
Bit rate : 12.0 Mbps
Nominal bit rate : 90.0 Mbps
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan order : Top Field First
Compression mode : Lossy
Bits/(Pixel*Frame) : 0.308
Stream size : 15.3 GiB (94%)
Audio
ID : 189 (0xBD)-128 (0x80)
Format : AC-3
Format/Info : Audio Coding 3
Muxing mode : DVD-Video
Duration : 3h 3mn
Bit rate mode : Constant
Bit rate : 448 Kbps
Channel(s) : 5 channels
Channel positions : Front: L C R, Side: L R
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Delay relative to video : -80ms
Stream size : 587 MiB (4%)
Results 1 to 1 of 1
RipBot264 Audio Sync Problems
By gonzalu in forum Video ConversionReplies: 7Last Post: 25th Sep 2024, 20:40 -
Ripbot264 audio options
By jamesj84 in forum Newbie / General discussionsReplies: 8Last Post: 8th Feb 2012, 18:22 -
Multiple audio structures in same film using Ripbot264
By rocks911 in forum Video ConversionReplies: 1Last Post: 7th Dec 2011, 10:09 -
Audio sync problem with RipBot264
By DirkGently68 in forum Video ConversionReplies: 2Last Post: 20th Nov 2010, 13:06 -
Need DTS Audio Out Using RipBot264 When Ripping As MKV
By bht42 in forum Blu-ray RippingReplies: 6Last Post: 17th Oct 2010, 05:42
