When you said 'latest Ulead' do you mean the one that is given away with that easycap you show ?
That one wlll NOT work with Win7.
The problem with easycap is that there are so many fakes around. You can only be certain you have the real deal by purchasing direct from the manufacturer. It is no longer called easycap/eascap DC60....... The genuine product is now called ezcap116.
Let me tell you what I would now be tempted to do in your position. Get yourself a dvd-recorder and dub/copy the tapes in that. Import the dvd in to the editing program of your choice and proceed from there.
Could I also ask if the tapes were your original recordings or copies you obtained from elsewhere. If they are just copies then you will never get a good capture from them with ANY equipment since the issues are already 'burnt' in. Put that down to experience.
Results 31 to 32 of 32
Okay, will check around for that kind of things! Thanks! ....this what much harder then I thought before beginning with this ;p
Which codec is the best for capturing VHS?
By aaxpers in forum Capturing and VCRReplies: 2Last Post: 27th Jun 2011, 06:45 -
VHS Capturing problems
By scratchmeback in forum Capturing and VCRReplies: 15Last Post: 10th Jan 2010, 21:04 -
capturing from VHS
By halbblah in forum RestorationReplies: 4Last Post: 1st Nov 2009, 16:35 -
Capturing VHS using All In Wonder HD
By ukcolonelcolin in forum Capturing and VCRReplies: 14Last Post: 2nd Dec 2008, 09:32 -
Capturing VHS Tapes...
By soneman in forum Capturing and VCRReplies: 31Last Post: 15th Jun 2007, 15:08
