Hey All,
Just wondering what does everyone find the best quality to convert a DVD to?
I used to convert to AVI & making sure I kept the same frame rate as original source & then leaving width as it was produced(720) but making the height slightly smaller to make it exact 16:9.
But then I found that MKV H264 was producing better watchable quality & at a lesser overall file size!
I have since found that some DVD's such as Entourage converting to MKV screws with the frame rate & looks CRAP & very slow especially when they move a bit quicker(doesn't happen as much with turtle LOL).
So what does EVERYONE have as their preference to covert to & using what program?
Cheers Grant
I encode with x264 at the original DVD frame size with aspect ratio flags. I use the MKV container.
The MKV files usually turn out between 1 and 2 GB. It takes less than the run time of the movie on my dual core Celeron E3200, even faster on my quad Core E6600.Last edited by jagabo; 25th Jul 2011 at 07:14.
Sounds Pretty cool!
I use either DVD shrink or DVD fab(depending on arccos)
The I check the original file with gSpot
Then try & reproduce using AVS Video Convertor & have all the same settings except for making it exactly 16:9 so there's no black lines on side or top!
I've recently tried handbrake & it's quite a small & compact & simple encoder too!
But I want to do it as good as possible so I'm happy to try all opinions so keep em coming!Last edited by GruntVidStar; 24th Jul 2011 at 23:50.
Which format to convert to for best quality?
By Crapozo in forum Video ConversionReplies: 5Last Post: 4th Feb 2011, 19:23 -
Convert to same quality- possible?
By mst in forum Newbie / General discussionsReplies: 9Last Post: 28th Dec 2010, 14:32 -
Convert DVD with choice of audio language and burned-in subtitle language
By theproof in forum DVD RippingReplies: 2Last Post: 24th Jun 2010, 17:34 -
best way to convert .ts to AVI with best quality
By Cazz in forum Video ConversionReplies: 9Last Post: 26th Oct 2008, 10:18 -
Best choice for high quality DVD printer
By lordhutt in forum ComputerReplies: 9Last Post: 8th Aug 2008, 02:37
