Hi,
I want to encode anime from DVD to a x264 vfr mkv.
I searched through the forum and I think I should encode in cfr and then mux the timecode to become vfr mkv.
However, my source is DVD. ffvideosource doesn't seems like work with DVD, can someone please teach me how to do it??
Thanks!!!
Results 1 to 14 of 14
Welcome to the forum. You can probably start here: https://www.videohelp.com/dvdbackup.
Just use single pass constant quality encoding. That will only use the bitrate needed to encode any given scene.
VFR is a solution without a (real) problem. And it causes more problems than it solves. I won't recommend it for anything except scientific research. Just like I don't recommend VBR audio. Not worth it.
olyteddy was referring to CQ VBR, but I know that's not what you were looking for.
A simple search on this site will give you what you are looking for (using cfr source + changed timecodes muxed in via mkvmerge, IIRC), but you would be causing a buttload of trouble for later playback (if no for you, then certainly for those you might want to share with). And because you don't actually ENCODE direct to VFR, it's not truly a filesize/bitrate savings like VBR clearly is (unless the app were to "re-edit" the frames).
Maybe that's why few have answered you...
Scott -
Different frame rate than what?
MeGUI is a GUI to CLI process such as AVISynth, X264, etc. The AVS script starts with an input source (in this case, DVD). There are a number of sources one can use. For DVD, particularly one with changes in Interlacing cadence, one of the best input sources is DGIndex/DGMPEGDec. It's likely, though, that it is NOT the default input source chosen by MeGUI. So you change your AVS script to reflect this, and possibly your Interlacing cadene difficulties (which is what I believe you're actually referring to when you talk about "different frame rate" stuff) will be taken care of.
Why don't you describe WHAT you've got to start with (title?) and what you want to end up with/how you intend to use it...
Scott -
Hi,
first I use file indexer to produce a d2v file of my ANIME DVD.
Then I wrote a AVS script as follow
LoadPlugin("C:\Users\nosmas\Desktop\MeGUI_2028_x86 \tools\dgindex\DGDecode.dll")
DGDecode_mpeg2source("J:\NO_MONEY\VIDEO_TS\VTS_03_ 1.d2v", info=3)
LoadPlugin("C:\Users\nosmas\Desktop\MeGUI_2028_x86 \tools\avisynth_plugin\ColorMatrix.dll")
ColorMatrix(hints=true, interlaced=true, threads=0)
LoadPlugin("C:\Users\nosmas\Desktop\MeGUI_2028_x86 \tools\avisynth_plugin\TIVTC.dll")
LoadPlugin("C:\Users\nosmas\Desktop\MeGUI_2028_x86 \tools\avisynth_plugin\deen.dll")
tfm(order=-1).tdecimate(mode=1,hybrid=1)
#crop
deen("a3d",3,3,1,3)
Spline36Resize(960,540) # Spline36 (Neutral)
LoadPlugin("C:\Users\nosmas\Desktop\MeGUI_2028_x86 \tools\avisynth_plugin\FluxSmooth.dll")
FluxSmoothST(7,7) # Medium Noise
Tweak(0,1.2,5,1)
__film = last
__t0 = __film.trim(0, 42485)
__t0
The result is not bad, but NOT PERFECT.
Some frame didnt deinterlace correctly...
Would you like a sample? If so I can upload it. -
I won't be able to look at it for a few days, and it's possible that others (jagabo, poisondeathray, etc) would be better at guiding you through all the AVISynth script choices.
However, it probably WOULD be a good idea if you uploaded a ~10sec clip of the original DVD rip.
Scott -
Encoding subtites to a VFR mkv
By Fadeout4 in forum SubtitleReplies: 2Last Post: 19th Feb 2012, 19:19 -
Encode mpeg2 mkv to AVC mkv using RipBot264
By PoloRoy in forum Newbie / General discussionsReplies: 3Last Post: 15th Aug 2011, 11:12 -
How can I encode using VFR, mp4 output?
By The Scenes in forum Newbie / General discussionsReplies: 4Last Post: 18th Apr 2011, 19:34 -
How to encode using VFR in meGUI ??
By Enkidu in forum Newbie / General discussionsReplies: 24Last Post: 16th Nov 2010, 21:26 -
VFR MKV to XVID MKV
By Shaorin in forum Newbie / General discussionsReplies: 2Last Post: 24th Nov 2007, 02:52
