Results 1 to 13 of 13
  1. Dynamitez
    Jul 2011
    Redcar, England, UK.
    http://forums.whirlpool.net.au/forum-replies.cfm?t=1000547&p=-1&#bottom
    Iv'e done the exact method it says in the tutorial above but when i try to join the filters together in graph it comes up with the stupid cant connect blahblahblah!
    Feb 2004
    Australia
    Welcome djdynamite123
    This is on the fly output
    Ffdshow may be better option where setup properly
    Q:
    How can I send the audio to my receiver instead of my PC speakers?
    A:
    Most receivers are able to decode AC3 and DTS audio. If you have connected your receiver to your PC with a digital cable, then you can send AC3 and DTS audio directly to your receiver by using S/PDIF pass-through.
    It is also possible to output other audio formats to your receiver by re-encoding the audio to AC3 in realtime.
    The location of the S/PDIF options depends on which decoder that you are using, either ffdshow or AC3Filter. The codec pack uses ffdshow by default.
    ffdshow
    In ffdshow audio decoder configuration, go to the "Output" page. There you can find checkboxes to enable S/PDIF pass-through for AC3 and DTS audio.
    If you also want to send the audio from other audio formats to your receiver, then you need to enable the "AC3 (S/PDIF encode mode)" checkbox under "Supported output sample formats".
    Only the audio that is processed by ffdshow will get re-encoded to AC3. If you also want ffdshow to process audio that has been decoded by a different DirectShow filter, then you need to go to the "Codecs" page in ffdshow configuration and set "Uncompressed" to "All supported".
    AC3Filter
    To activate S/PDIF output, enable the checkbox called "Use SPDIF" that is located on the "Main" tab.
    All S/PDIF options in AC3Filter are located on the "SPDIF" tab.
    If you want AC3Filter to process audio that was decoded by a different DirectShow filter, then you need to enable PCM on the "System" tab.
  3. Dynamitez
    Jul 2011
    Im already using FFDshow to encode ACC into AC3 with GOM player but i need a way to play a few particular games in 5.1 using the method i mentioned in the link, but when i go to link the filters together using graphedit it just says cant connect them blahblah.. :/
  4. DECEASED
    Jun 2009
    Heaven
    Please post a screen shot of your Graphedit / Graphstudio error message. Also, try AC3Filter instead of ffdshow's audio decoder.
  5. Dynamitez
    Jul 2011
    Ahh finally got it to work but audio is delayed by like 1-2 seconds .... Perhaps it doesn't help with me using a 10m HDMI and 10m optical cable....... Is there a way to speed up the audio?
  6. The cable doesn't matter. To get a 1 to 2 second delay from the cable you would need about 186,000 miles of it.
  7. Dynamitez
    Jul 2011
    hmm, why is there a big delay then? ... dont have this issue with AAC to AC3 with ffdshow and GOM/KMPlayer.
  8. One of the filters may be buffering.
  9. Dynamitez
    Jul 2011
    I hope someone knows of the fix
  10. I would look at the internal settings of AC3Filter. Also make sure your amp isn't set to delay.
  11. Dynamitez
    Jul 2011
    There are no delays on the amp, otherwise i would have delay when using FFDshow aac to ac3 encoding on the fly in movies. I don't know what settings to look for in AC3Filter.
  12. That pretty much leave AC3Filter as the cause of the delay. Right click on it in GraphEdt and and select Properties. Look through the options for a delay setting.
  13. Dynamitez
    Jul 2011
    That's the thing there is no delays in AC3Filter neither, all set at 0. :/
