Hi,
I've created backup of a Blu Ray disc, removed extras I do not need and was going to burn it on a Blu Ray. But I see ANY! folder in it. What is it? Do I need it? Will the disc play back on stand alone with this ANY! or I should get rid of it? And how? Tried to find something about it but could not. Thank you!
Silly question, perhaps, but what is actually in the folder?
If cameras add ten pounds, why would people want to eat them? -
What I meant was, what are the contents of the ANY! folder, if there is anything in it?
No, you don't need the ANY folder. And for those using DVDFab, you don't need the FAB folder. I suspect those folders contain information that may be useful to the programs' makers should you need to contact support about trouble decrypting certain discs and/or report a bug.
Pull! Bang! Darn! -
Sorry for the late reply. Was away.
There is a number of files in the folder. In total, about 6 MB.
Fritzi, when you are saying, we do not need it, do you mean I do NOT need to include it into the files I load for burning? Can leaving it out violate the structure? Thank you!
batch dvd ripping - output folder to input folder?
By mkv2avi in forum DVD RippingReplies: 5Last Post: 17th Apr 2012, 17:23 -
Wgat would be the proper folder structure to add movie cover to a folder
By VoodooEvil in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2012, 20:09 -
WPDNSE folder inside your system Temp folder????
By MozartMan in forum ComputerReplies: 25Last Post: 27th Mar 2011, 09:35 -
AUDIO_TS folder
By siluet in forum Newbie / General discussionsReplies: 14Last Post: 10th Oct 2009, 08:00 -
Destination Folder
By Gripweed in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 16th Jul 2007, 13:28
