I know I can use DVDSubEdit to reposition &/or re-color subs in the VIDEO_TS file (which I do quite frequently), but is there *any* program that can reduce the font size or change the font type used? (WITHOUT having to rip the files apart and do conversions?)
Thanks!
	That would require at least creating (encoding) new subtitles and re-authoring. The existing video and audio can be re-used without conversion.
	To clarify, DVD-Video subtitles are stored as vobsubs - in a bitmap format, as images. To change the font or text size, you'll have to re-create most or all of those images.  If cameras add ten pounds, why would people want to eat them? If cameras add ten pounds, why would people want to eat them?
	Ok. Thought that might be the case, but was hoping there might have been some new software out that could do it.
 Thanks much for the fast responses
	With English Subs I've been very lucky with DVDSubEdit
 Import the subs from the DVD. Do automatic OCR. Export to .srt. Often I get an .srt ready to go. If there are errors you can often find them quickly by searching on the underscore character '_'. Seems when I get errors the line of dialog looks like "_&%%_$*__" gibberish. The gibberish always seems to have at least one underscore character.
 This also works well for PGS subs that have been downsized to 720x480 using BDSup2Sub and exported either as idx/sub or ifo/sup. It only takes a few minutes and doesn't alter the DVD source. Worth a try.http://milesaheadsoftware.org/
 Fully enabled freeware for Windows PCs.
  Add new subtitle to an existing DVD with warning screens, intros & trailersBy Charmer in forum Authoring (DVD)Replies: 7Last Post: 11th Aug 2011, 18:59
  Reduce file size .By pensioner in forum Newbie / General discussionsReplies: 4Last Post: 10th Dec 2010, 15:08
  Reduce file sizeBy windranger in forum Newbie / General discussionsReplies: 1Last Post: 13th Aug 2010, 10:18
  Help with Subtitle Fonts?By aeslis in forum ffmpegX general discussionReplies: 2Last Post: 22nd Sep 2009, 08:23
  How to embed subtitle and reduce file size to be playable online? [SOLVED]By mriddler in forum SubtitleReplies: 3Last Post: 5th Apr 2009, 07:38
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
