Thus far, I've used autoGK, and found it to work well, except for when a DVD has several .ifo files, in which case you have to add and process each file individually, as there doesn't seem to be any kind of batch processing function. So basically what I'm looking for is a program like autoGK which does permit batch processing of the .ifo files. If not, perhaps there's a way to merge all of the .ifo files into one file and then just add that one file to autoGK. Since I don't know of any, I tried to just merge several .vob files together, planning to afterwards convert them into an .avi file or something. However, when I merged about 13 .vob files together from a disc using VOBMerge 2.52, it came out terribly. So does anyone have a best solution?
avi.net can do batch encodes, but there's more programs that do it, ffcoder, xmediarecode, etc, search the tools section
I love it when a plan comes together! -
You have to set up each one individually, but after that's done it'll process them all one after the other.
Or, if you're for some reason trying to join a bunch of unrelated smaller videos into a single big video, just renumber the VOBs sequentially, load the first one into AutoGK, and the rest will get loaded automatically. -
What you're looking for is a "batch encoder". Like Procoder, SorensonSqueeze, Cleaner (older), etc. you want a converter that let's you set up an encoding settings "template" and then have any files in the queue converted according to that template. That includes auto-filenaming.
However, unless you're using "watch folders", you'll still have to MANUALLY added each item to the queue - it's a NECESSARY hassle. Even with watch folders, you still have to manually add them to the folder. NECESSARY.
Scott -
easiest method to convert movies with multiple m2ts files (seamless branch)
By zero7404 in forum Blu-ray RippingReplies: 3Last Post: 22nd Aug 2011, 09:10 -
Quickest method of converting avi to DVD ???
By blinky88 in forum Video ConversionReplies: 15Last Post: 10th Oct 2009, 02:09 -
Easiest and fastest way of converting MKV files to be played on HDD player!
By kebabtomten in forum Video ConversionReplies: 2Last Post: 2nd Dec 2008, 22:33 -
Easiest method to rip a DVD to a Windows Movie Maker compatible format
By computer2slow in forum DVD RippingReplies: 6Last Post: 9th Apr 2008, 20:11 -
Easiest method for Mac (Leopard) DVD backup?
By derrek.mcnab in forum MacReplies: 15Last Post: 12th Mar 2008, 21:30
