I have read elsewhere that video resizing should not be done on interlaced source to avoid quality loss. My souce is 16:9 1920x1080 top field first interlaced source 29.97 frames per second (I assume that it is 60 fields per second). I am using avisynth and HC to do the conversion. My goal is highest quality for the conversion rather than speed. I am assuming that the avisynth script is feeding 29.97 frames per second progressive input to the HC encoder.
Is the below the right approach for this? Comments will be appreciated.
Thanks,
AVISYNTH file:
LoadPlugin("DGDecode.dll")
MPEG2Source("c:\temp\temp\video.d2v")
Load_Stdcall_plugin("yadif.dll")
AssumeTFF()
Yadif(Mode=1,Order=-1)
SelectEven()
AssumeFPS("ntsc_video")
Spline64Resize(720,480)
HC ini file:
*INFILE c:\temp\temp\video.avs
*OUTFILE c:\temp\temp\video.m2v
*LOGFILE c:\temp\temp\video.log
*BITRATE 6565
*MAXBITRATE 9000
*ASPECT 16:9
*PROGRESSIVE
*MATRIX MPEG
*PROFILE BEST
*WAIT 0
*NOSEQ_ENDCODE
	Is your source interlaced (60 different images per second) or telecined film (24 different images per second)? If the latter you will be better of with an inverse telecine:
 Encode to MPEG 2, progressive with pulldown flags.WhateverSource()
 AssumeTFF()
 TFM()
 TDecimate()
 WhateverResize(720,480)
 For true interlaced video, if you really want the best quality, use QTGMC() instead of Yadif(). Then resize and use SeparateFields().SelectEvery(4,0,3).Weave().
 QTGMC is very slow. Use Yadif(mode=1, order=1) instead of QTGMC() in that sequence if you need faster conversions. Or check out QTGMC's faster presets. Encode to interlaced MPEG 2.WhateverSource()
 AssumeTFF()
 QTGMC()
 SeparateFields()
 SelectEvery(4,0,3)
 Weave()
 For fast and dirty use:
 AssumeTFF()
 SeparateFields()
 WhateverResize(720,240)
 Weave()Last edited by jagabo; 23rd Jul 2011 at 12:26.
	Don't forget to add a ColorMatrix line when converting from 1080i to 480i/p as well:
 And I agree with jagabo, make sure it is actually interlaced footage. If you are talking about 1080i material from most ATSC broadcasts, it will likely be film material originally.Code:ColorMatrix(mode="Rec.709->Rec.601")
 If it is interlaced, you can use a faster preset in QTGMC to still get a lot of benefit from the script over what you can get out of just yadif alone. The following will run QTGMC using yadif rather than NNEDI2/3 or EEDI2 as the interpolator. It still eliminates the bob shimmer.
 Code:QTGMC("Ultra Fast") ## <-- can change to "Ultra Fast",TR2=1 [or 2] if you still have issues with bob shimmer.
  SANYO VPC-GH4 1080i 60 fields/sec reported as progressive at 60fpsBy johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 3Last Post: 16th May 2011, 22:43
  Recording 1080i 60 fields/sec vs 1080p 30 frames/secBy johnnyquid in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 4Last Post: 4th Apr 2011, 07:38
  How can I convert a 1080i ".TS" file to DVD-compliant MPEG-2?By kiwisoup in forum Video ConversionReplies: 2Last Post: 11th Jan 2009, 23:04
  How can I convert a 1080i ".TS" file to DVD-compliant MPEG-2By kiwisoup in forum Video ConversionReplies: 1Last Post: 11th Jan 2009, 18:53
  suggestions for a dvd compliant mpeg2 encoderBy uglijimus in forum Video ConversionReplies: 4Last Post: 15th Dec 2008, 00:58
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
